Need some advice
Old May 11, 2020 | 01:28 PM
OneQwikSS's Avatar
formerly 2004RST (changed 11/19/2012)
Default Need some advice
Alright guys I’ve got a tbss that spun a bearing so I through the wallet at my motor...stroked to 404 (-3 4.010 wisecos 6.125 k1 Rods & 4” crank) l92 heads with .020 off (65cc chambers) planned on running ls9 gaskets (.051 compressed thickness) but with every piece of math I do I’m coming back at a 12.3 SCR and roughly a 9.7 DCR on the custom grind vengeance racing cam...(49.4 ABDC) now I’m not afraid to run race gas and clearly that’s the only option this setup would even entertain because I refuse to allow 93 to be the answer at 14* of timing across the table 😂 so if I go with a thicker gasket (don’t want to spend anymore money at this point) how much gasket would you guys feel safe to provide proper quench and still be able to hit it with a 200-250 shot in a progressive setup? Thanks for any info...been awhile since I’ve even been on here!!!
Old May 11, 2020 | 09:28 PM
MikeGyver's Avatar
I have read that quench must be less than .055" to work, and between .055 and I think it was .155 will actually be more prone to detonation than a non quench combustion chamber.
Old May 12, 2020 | 12:15 AM
arthursc2's Avatar
Put some stock heads on that thing 👌🏻
Old May 12, 2020 | 01:22 PM
MikeGyver's Avatar
Old May 12, 2020 | 03:07 PM
OneQwikSS's Avatar
They’re hand ported 823’s with .020 off
truck will be on 93 & 85 standalone system for n2o
deck height should be 9.235 prob gonna swap from ls9 gasket to cometic .080 just curious how that will affect the 250-300 hit through a progressive
quench should be .056 on the ls9 gasket
.085 on .080
Old May 12, 2020 | 03:37 PM
madmann26's Avatar
I’ve dailied 12.5:1 for 2 years now.
Timing up top is 22 degrees.
93 Octane
Old May 12, 2020 | 06:07 PM
arthursc2's Avatar
Purely opinion, but I think you're going the wrong way on the gaskets. Stock heads or get some CNC'd chambers: I wouldn't go more than .051 on the HG thickness
I also think there's an echo in here 🤨
Old May 15, 2020 | 08:27 PM
GREENSIERRA's Avatar
I run 27* with 11.7 on 94 Oct. I bleed off alot of compression with my cam tho.
Old May 26, 2020 | 07:17 AM
OneQwikSS's Avatar
Thx for some of the opinions guys...kinda just gonna send it with the ls9 gasket and see where she’s happy...using a terminator x Max as my ecm...what’s the worst that could happen 🤦🏻‍♂️
Secondhand SS
Jun 10, 2012 05:40 AM
RcrX
Oct 12, 2009 08:56 PM
1slow01Z71
Sep 30, 2005 06:53 PM
