Need help choosing cam for lq4 swap
Old Mar 6, 2018 | 09:50 PM
Seve's Avatar
Registered User
Thanks for the help all be going with the btr stage 2 truck cam I think thats my best option
Old Mar 28, 2018 | 10:14 PM
SLW6OH's Avatar
Originally Posted by Seve
Am doing my first ls budget swap and I need help choosing the right cam for my lq4 engine.
lq4 4l80e tranny out off a 2000 suburban 2500 going into a 94 c1500 shortbed am planning on milling the 317 heads .30 any help will be appreciated
Your build is almost identical to mine, 92 silverado 6.0/4l80e from a 2001 2500 Suburban. It was also my first LS build that I tried to keep budget friendly, between the body and swap running and driving with only headers and a CAI i had about 5k into it. I love the truck but the time has come to start making more power so I'm also looking for cam options. I've been looking for 243 or 799s but keep hearing about milling the 317s and saving a few dollars. I picked up a nnbs intake and injectors with a 90mm TB so I'd like to cam it around the same time to save on the tune. Not sure about you but my truck is a weekend warrior doesn't see much Monday through Saturday action so I'm not against a big cam and stall but those are both things to consider on yours. Where ever you decide to get your cam from talk to a rep and get there opinion with your setup. Good luck hope it all works out for you!
Old Mar 30, 2018 | 11:06 PM
01FormulaTA's Avatar
TSP 212/218 .600 .600 114LSA <<< THE perfect cam for your goals
Old Mar 31, 2018 | 08:03 AM
10 Second Club
I have an EPS 214/220 in my daily driven truck. Good manners, lots of TQ. Great all around cam. Get something similar to what I have and you will be happy. I had a smaller cam initially, ran OK but had me wishing I had went with a larger cam. This one fits the bill.
Old Mar 31, 2018 | 03:16 PM
BlackPanther6.0's Avatar
I had the btr stage 2 in my 6.0 with 4l60e stock stall and it was amazing. Stepped up to a similar as the stage 3 and noticed very minimal low end drop. I think the 4l80e has a converter that flashed to like 2200 if I'm correct? But the btr stage 2 is heard to beat. Power everywhere with it
Old Apr 7, 2018 | 01:37 AM
Seve's Avatar
Registered User
Ok so I went with a btr stage 3 truck cam on my lq4 I also bought some 243 heads and ls7 lifters will the stock 7.4 pushrod work or should I go shorter?
Old Apr 7, 2018 | 09:27 AM
You should be ok with the 7.4 that's what I was running. Milled 799s .030 LS7 lifters and the btr cam
Old Apr 7, 2018 | 03:16 PM
SLW6OH's Avatar
What made you change your mind from the stage 2 to stage 3?
Old Apr 7, 2018 | 03:49 PM
I wanted more to end, it gained only 8rwhp and 19 torque but gains where everywhere in the curve. I will change cams again later on maybe in a year. I like experimenting so I can give my friends the best advice on what works. I guess you can say I'm the Guinea pig lol I want to try the streetsweeper 220/224 and lastly the tick SNS stage 1 for LS2 which I have in my GTO.
I really didn't notice much of a low end loss, it still takes off like before but I can really feel it come in hard at 3k
dgreer30
Nov 2, 2013 12:45 PM
tenman33
Jun 29, 2011 09:52 PM
stssilverado
Jan 14, 2007 03:49 PM
graysilv
Sep 21, 2006 02:37 PM
