Need Help ASAP!
Old Feb 29, 2008 | 03:16 PM
00Silv4.8's Avatar
Default Need Help ASAP!
looks like I have an opportunity to put my cam in, cuz one wont come around for another 4 months or so. I need to know any advice, or special tools Im gonna need (other than a lifter tool and a 'cam handle'? I guess u'd call it), but Im doin it at my buddy's shop ironically the same one my dad works at, but hes an import guy and has a side job so he wont be a lot of help. And lifters, I need to know how to get mine out? pen magnet? and maybe just a simple step by step walk thru of how to do it. I have confidence but just could use some light from above I guess Thanks everyone
Old Feb 29, 2008 | 03:21 PM
thunder550's Avatar
High on diesel fumes
Have you looked through this article? It's for an f-body, but it is essentially the same in the trucks.
http://www.ls1howto.com/index.php?article=23
You can't remove the lifters without pulling the heads.
Old Feb 29, 2008 | 03:32 PM
bigbadwolf54's Avatar
13 Second Truck Club
sounds like you've got it mostly covered...dont forget the balancer puller, and all of your gaskets/fluids
Old Feb 29, 2008 | 03:41 PM
Nick™'s Avatar
why pull the lifters??? the stock ones work just fine in performance applications.
how much lift on the cam? you replacing valve springs?
Old Feb 29, 2008 | 04:07 PM
00Silv4.8's Avatar
yeah springs rods and Lunati and my dad recommended replacing the lifters just because ya know, some good insurance I guess. Gotta pull the heads tho huh?.. hmm.. I only have gaskets for the valve covers intake and timing cover crank seal a huge bolt and 2 identicle ones with a circle and square bores and 3 holes for bolts it looks? enlightenment? and harmonic balancer puller? y?. my cam has .558 lift and what will I need besides dex-cool? oil?
Old Feb 29, 2008 | 04:08 PM
00Silv4.8's Avatar
oops, and I have the timing chain too. anything Im missing?
Old Feb 29, 2008 | 05:02 PM
xlcooplx's Avatar
http://ls1howto.com/index.php?article=23
5/16 dowel rods IMO. Pulley puller. 24mm socket for crank bolt. Valve spring compressor.
Old Feb 29, 2008 | 08:00 PM
00Silv4.8's Avatar
cool thanks. Little bumming update tho. The guy who was gonna let me use his stall bailed on me so now if I wanna do it I guess I could run up to my dad's shop and grab a case of tools for this and do it myself in my drive way. I guess I got the cajones but then again I would like someone to atleast oversee my work. Any takers? haha Ill throw some beer money or some lunch in it. I guess Ill sleep on it and decide if I wanna work on my truck or get paid for the day
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
