need advice on a 5.3 vortec engine swap into a 71 chevy
Old Dec 17, 2007 | 08:39 PM
71CHEVYCSS's Avatar
Registered User
Default need advice on a 5.3 vortec engine swap into a 71 chevy
I Was Lookin At Painless Performance And The Wiring Harness Kit Cost About 600 Dollars And I Dont Wanna Spend All That Is There Any Otha Way I Can Make It Work With The Stock Wiring Harness Of The 2002 Silverado?
Old Dec 18, 2007 | 07:10 AM
Yeah you can make it work.Go to the top of the page and click on ls1 tech then go to conversions and hybrids,everything you need to know is there just search and find.My brother just put an iron ls1,4l60e in his 67 swb pretty easy swap.
Old Dec 18, 2007 | 10:42 AM
custom 68's Avatar
I have one in my 68 SWB and I went with the painless harness. At the time it was the cheapest if you were going to purchase. The harness had everything and was labeled very well. I have my original and plan to convert it some time for my next install.
I had just made one for a TPI I had in my truck, the motor shot craps within a week or 2 of install so I was frustrated with messing with it so I just bought one.
Good luck.
Dave
Old Dec 18, 2007 | 11:53 AM
TURBHOE's Avatar
you could also use a carb and there is a new piece that bolts to the front of the motor and you can use a ford distributer on it. seen it on horsepower tv. then you wouldn't really have any wireing to do.
Old Dec 19, 2007 | 12:21 PM
Compressor Surge's Avatar
John at Speartech can and will hook you up. I had him rework the factory harness for my 5.3 into 1969 C-10 conversion, and it was only $400 or $450 (can't remember). It's tested, and ready to go.
He had a two week turnaround time for my harness. Not bad, IMO.
Old Dec 19, 2007 | 01:15 PM
custom 68's Avatar
I have heard nothing but good things about Speartech I would look at that pretty serious. John can get you fixed up.
Old Feb 11, 2008 | 10:34 AM
PainlessTexas's Avatar
FormerVendor
Hi. My name is Gary Wright. I am with Painless Performance. Our 60217 harness will do the job. Plug it into the sensors and then you will have 3-4 wires you will need to mate to the factory chassis harness. Harness includes a fuel pump relay and enough wire to run to the back of most trucks for an intank fuel pump.
One thing to keep in mind. Our harness will be more expensive than a reworked factory harness or wrecking yard harness of questionable condition. But, you will get all new wire and connectors. We use the same OEM connector components as GM and the highest grade of automotive wire (TXL) available. Terminals are machine crimped on an Amp press to insure uniform retention. Each harness is then installed on a test board that checks continuity on every circuit before it goes in the box. We provide the best instructions in the industry and have a toll free tech line to help should you have questions or run into a problem. You can go to our web site and check out the instructions. Even download a pdf if you wish. Click on Installation Manuals under the TECHNICAL heading on the left hand column of the home page www.painlessperformance.com
Any questions?
Old Feb 13, 2008 | 08:14 PM
billyjo's Avatar
I also have a speartech harness, he initially tuned my computer and got all my DBW stuff from him also.
Old Oct 20, 2010 | 08:30 PM
brianctaylor's Avatar
Registered User
Default 86 chevy
i was wondering if anyone could help me out i have a 86 chevy with a 5.3 in it and it dies on me sometimes when im driving it when it gets worm and then sometimes when i have been driving it for a while and i shut it off and start it back up it acts like its not getting any fuel like bogs down for a sec then its fine can any one help with this problem
Old Oct 21, 2010 | 02:48 AM
67firebirdak's Avatar
Well you could mess around with a distributor, but it might be easier to use the MSD 6010 box. That's what I'm running on my 5.3 and it works great! For a daily driver though, I'd definitely go with fuel injection.
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
EscaTruck
Jul 20, 2015 11:42 AM
4B11T
Jul 13, 2015 03:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
