NA heads for 6.0
Old Aug 21, 2008 | 03:05 PM
skeet's Avatar
Originally Posted by lsx10
i'm with the most everyone else here, go with ported 5.3's or 243s. both are great choices, I've heard alot of hype about the l92 stuff, but the setup really doesn't impress me.
yep i agree about the hipe!!! but i am one to try it lol
wouldnt 243s have to be milled pretty good to get the compression up on the 5.3 ?
i know 5.3 heads will raise the compression without being milled, but not sure about the 243
Old Aug 21, 2008 | 03:22 PM
v8
17,16,15,14,13,12,11 Drvr
243 63cc?, 5.3 heads 62-61 cc depending on what book you look at. Not 100% on the 243 but should be close.
Old Aug 21, 2008 | 03:32 PM
TurboGibbs's Avatar
Agreed with the L92's being best on 400+ inches. Also agree that the L76 intake becomes a restriction above 6000, even on a 6.0. I have the L92's and do not like how much torque i've lost on the low end. If you have a 6.0 and a 3000+ stall and a larger cam, then the L92's may do pretty good for you. If you have a more mild set up then ported 5.3's or 243's is the better way to go. Besides, the L92's have a 69-70cc chamber to consider as well.
I have been running the L92's for over a year and will be swapping back to cathedral port soon. I really could use the low end tq due to me being a manual trans.
I put down 413/401 with my L92's
greedygenius
Sep 3, 2015 06:51 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
