n/a or boost?
Old Nov 24, 2012 | 02:15 PM
lukn4trbl355's Avatar
Default n/a or boost?
hey everyone i had a few quick questions about an aspiration change. before i plan anything out any further i figured id get some opinions. ive always been an all motor guy but im starting to want to experiment with boost lol. ive got a 2001 silverado with a 4.8 in it, its a full bolt on truck with a pretty healthy cam,custom tune and has a fully built drivetrain.
my orignal plan was get rid of my 862's and go for a set of prc stg 2.5 heads as well as yella terra rockers, but now im kindve stuck since i cant debate wether i want to stay n/a or go f/i. the prc's come with two options for combustion chamber size, 58 and if i remember a 63? i was going to choose the 58, get a thinner set of headgaskets, and depending on PTV clearance get the heads milled down further for more compression, and if i really needed to, fly cut the pistons. but now im thinking mabey i should go with the larger CC and slap a d1sc on it? ive got a little time to think about it but before this truck goes in storage for winter id like to have my plan set, and hopefully parts in hand. i saw a write up on ls1tech about a member using the 228R cam on a 112lsa with boost and he put some damn impressive numbers down and it made me rethink things.
in honest opinion what do you think the best route? i know theres pros n cons to each aspiration but im stuck being indecisive lol
thanks
t.j.
Old Nov 25, 2012 | 04:34 PM
E40_Guy's Avatar
Registered User
Boost it and call it good. Good luck with the build either way
Old Nov 25, 2012 | 04:45 PM
Link2603's Avatar
Go FI you won't regret it.
Old Nov 26, 2012 | 12:00 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
We can set those cylinder heads up to go anywhere between 63cc and 58cc, depending on what you are looking for. But I think a procharger with your setup would be the best route as well...
Old Nov 26, 2012 | 01:38 PM
thanks for the help guys, i appreciate it. if i do end up going boosted its definitley gonna be a whole new ballgame to me, every build ive done has been all motor but i think it may be time to convert lol. as for boost im sure i wont regret it if i do go that route, and when this motor does finally pop ive got my eyes set on a shortblock id really like to build. and jake i figured if i did go with a HC build id get the 58s and have them milled a little to increase compression a little more, the only thing that scares me is PTV clearance. how far do you think i could mill them without running into any issues/without having to fly cut the pistons? im running the TSP228R on a 112lsa
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
