n/a 6.0 build questions
Old Nov 7, 2009 | 10:32 PM
custm2500's Avatar
Ph.D. in HUBRIS
If you want to make real big power building a 408 is you best bet! A simple 408 build should make you 450-500 at the wheels. I am stroking my 6.0 this winter. Hoping to start in about a month! Stock the 6.0 will make you some good power but if you want to really build an engine then you need to stroke it!
Old Nov 8, 2009 | 09:47 PM
Black'Rado's Avatar
Originally Posted by zippy
I'd agree with the Trick Flow or AFR thing, if you can hack the price they are worth it. It is tough to beat the price of the TSP heads though. As for cam, what are the specific's.
Year of truck:
Model:
Trans:
Converter:
Gear:
Tires:
List of current mods:
Possible future mods:
Goals for truck:
Uses of the truck:
Its a 01 ext cab silverado 1500
stock converter-plan on a circle d or yank 3200
gears-3.43 plan on 4.11 or 3.73
tires- 275/45-20 khumo exsta-want to get a set or drag radials for the 20's and a slick on my 16's
current mods-blackbear live tune, magnaflow single in dual out, k&n air filter, ls1 fans
future mods- built tranny, yank or circle d 3000-3200 stall, big tranny cooler, detroit tru trac and gears, and of course a built 6.0 and eventually a little wet shot
goals-would be awsome to see high 12's or low 13's
uses- daily driver or weekend toy if i get somethin else to drive
also after i sell my blazer ill have about 5-6 grand to build this motor and for supporting the power mods..... so kinda budget
Old Nov 9, 2009 | 09:09 AM
408's are pretty sweet.
Old Nov 9, 2009 | 09:23 AM
MPFD's Avatar
11 Second Truck Club
Don't get screwed like I did and buy a 99-00 6.0 block with the longer crank flange! Then you will have to have Yank build you a $$$ converter and run a '00 2500 HD flex plate like I'm doing.
Old Nov 9, 2009 | 11:52 AM
Black'Rado's Avatar
So I need a 01 up motor. And the 408 sounds good. Texas speed has a rotating assembly fairly cheap...that's probly my best option huh?
2500ZL1
Jan 25, 2016 06:30 AM
USMCvet0311
Aug 14, 2015 10:28 PM
USMCvet0311
Aug 1, 2015 07:45 AM
justuc
Jul 24, 2015 11:52 PM
4B11T
Jul 13, 2015 03:48 PM
