n/a 6.0 build questions
If you want to make real big power building a 408 is you best bet! A simple 408 build should make you 450-500 at the wheels. I am stroking my 6.0 this winter. Hoping to start in about a month! Stock the 6.0 will make you some good power but if you want to really build an engine then you need to stroke it!
I'd agree with the Trick Flow or AFR thing, if you can hack the price they are worth it. It is tough to beat the price of the TSP heads though. As for cam, what are the specific's.
Year of truck:
Model:
Trans:
Converter:
Gear:
Tires:
List of current mods:
Possible future mods:
Goals for truck:
Uses of the truck:
Year of truck:
Model:
Trans:
Converter:
Gear:
Tires:
Goals for truck:
Uses of the truck:
stock converter-plan on a circle d or yank 3200
gears-3.43 plan on 4.11 or 3.73
tires- 275/45-20 khumo exsta-want to get a set or drag radials for the 20's and a slick on my 16's
current mods-blackbear live tune, magnaflow single in dual out, k&n air filter, ls1 fans
future mods- built tranny, yank or circle d 3000-3200 stall, big tranny cooler, detroit tru trac and gears, and of course a built 6.0 and eventually a little wet shot
goals-would be awsome to see high 12's or low 13's
uses- daily driver or weekend toy if i get somethin else to drive
also after i sell my blazer ill have about 5-6 grand to build this motor and for supporting the power mods..... so kinda budget
Don't get screwed like I did and buy a 99-00 6.0 block with the longer crank flange! Then you will have to have Yank build you a $$$ converter and run a '00 2500 HD flex plate like I'm doing.
