N/A 408 power?
Old Feb 21, 2007 | 01:29 PM
adam1803's Avatar
Default N/A 408 power?
Just wondering if any of you guys running N/A 408s have any power numbers you'd share. Im seriously starting to think about building a 408 and running a shot of nitrous instead of my turbo 370. Just wondering what kind of power i can make on motor.
Old Feb 21, 2007 | 05:02 PM
GoatChs's Avatar
There are plenty of dyno results for N/A 408s on LS1tech...it mostly depends on how far you want to go! With a 150 wet shot there are guys with close to 700rwhp, albeit in cars.
Old Feb 21, 2007 | 05:23 PM
Derek @ EDO's Avatar
FormerVendor
550 RWHP NA is easily attainable over 800+ on spray!
Old Feb 21, 2007 | 05:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt say 550rwhp is easy, it takes CAREFUL planning and a damn good intake and heads with a large cam to do. We will see in the coming months how the L92s react. Most decent 408s are in the 500-520 range after that the power is hard to come by. When looking at dynos on tech look to see if its a manual or auto and what rear end and what dyno they are on, all those play a huge factor. I wouldnt worry too much about dyno numbers as they are only a little nudge of the correction factor away from being bling numbers. Might want to talk to Rhino or Wood Hauler he has a stout setup.
Old Feb 21, 2007 | 05:48 PM
tarinitup's Avatar
9 Second Truck Club
My 402 will be tuned March the 2nd at Nelson's so I'll let everyone know how it does. I doubt there's much power difference between 408 and 402.
Old Feb 21, 2007 | 06:10 PM
adam1803's Avatar
I am planning on running a 150 or 200 wet shot on top of it. As long as i can get 400-450rwhp with 317 heads and a decent sized cam i'll be happy. The nitrous will just be for the track and for "insurance" on the street.
Old Feb 21, 2007 | 07:06 PM
litreddevil's Avatar
Banned
be carefull i was told that they are haveing problems lifting heads with more than a 200 shot with high compression
Old Feb 21, 2007 | 07:51 PM
quicksilverado's Avatar
Have you considered gas mileage difference between the two?
Old Feb 21, 2007 | 07:57 PM
LSUxBlake's Avatar
550rwhp N/A is not easily attainable with a 408, there aren't many doing that.
Most seem to end up in the 500-520rwhp range.
Old Feb 21, 2007 | 07:59 PM
1slow01Z71's Avatar
Is there an echo in here?
