My "Rex" 408 is here!
Old Jul 16, 2007 | 01:53 PM
  #71
kbracing96's Avatar
Originally Posted by Thunder550
I'm not sure what he's reading right now, he's still in Wyoming.
Originally Posted by vanillagorilla
More like Kyle=Your ride home
Old Jul 16, 2007 | 02:02 PM
  #72
Tootall's Avatar
so what did you end up doing with the old setup?
Old Jul 16, 2007 | 03:34 PM
  #73
thunder550's Avatar
High on diesel fumes
Rex reused everything except the cam, heads, and pistons. Richard took the heads back on exchange, cam is sold to Kyle, and the pistons are for sale on tech.
Old Jul 16, 2007 | 03:36 PM
  #74
thunder550's Avatar
Yeah, but I was asking how your engine was running.
Kyle=Dipstick HA!!
How is he supposed to drive me home when he's 1200 miles away?
I'm still getting a little bit of oil smoke out the tailpipe, but under different circumstances that I was with the old engine. I spoke to Rex this morning about it and he thinks it might be the oil seals on the turbo.
Old Jul 16, 2007 | 04:22 PM
  #75
vanillagorilla's Avatar
I've heard of some rings doing that for awhile until they break in.
So do you feel a power increase? You should be able to feel some difference even though yo're baby'ing it.
Old Jul 16, 2007 | 04:23 PM
  #76
thunder550's Avatar
Throttle response seems much snappier, and I can feel it start to pull pretty good at part throttle as soon as it passes 2000 RPM.
Old Jul 16, 2007 | 08:59 PM
  #77
thunder550's Avatar
I got it smoking pretty good a little bit ago...I'll have to get some video. It doesn't act the same as it was before, so I'm hoping it's not an issue with the engine. I need to pull the turbo off and see if there's oil in it. I am not a happy person right now
Old Jul 16, 2007 | 09:32 PM
  #78
Stoichiometric's Avatar
What type of PCV do you currently have hooked up? That can definetly be a cause of oil ingestion, I hope you get it figured out.
Old Jul 16, 2007 | 09:54 PM
  #79
thunder550's Avatar
I have an LS6 valley cover into the intake manifold, then the passenger side valve cover runs to a catch can and the to a fitting right behind the air filter.
I tried to get it to smoke again after sitting for about 30 minutes and it wouldn't. I'm thinking that the oil seal in the turbo is going, and that the oil will leak but won't get hot enough to smoke until the engine has run for a couple minutes. I need to pull the downpipe off the turbo and also the pipe between the turbo and intercooler and see what they look like.
Old Jul 16, 2007 | 10:04 PM
  #80
TurboGibbs's Avatar
I hate it if it is. I bought it new and put just a few thousand miles on it + whatever you put on it before. If you need it to be gone through I personally know some of the best guys in the business.
