May have run into a problem during cam install
Old Feb 28, 2016 | 05:43 PM
lopy6oh's Avatar
Default May have run into a problem during cam install
I just got my tsp 220r cam, pac springs, and hardened rods delivered and figured I start on the install on my 2012 2500hd 6.0. Keep in mind this is my first cam install so sorry in advance for any dumb questions. I called three different dealerships to see if my truck has dod or vvt. All three said no on both after looking up my vin. Well, I get down to the step of removing the water pump only to find what appears to me as a vvt timing cover. Can anyone confirm this before I go any further? And if it is in fact vvt, whats my next best course of action? I've seen comp cams makes something to modify the vvt cam gear but I figure I'd get some advice before I go spending more money.
Old Feb 28, 2016 | 05:51 PM
FFDP's Avatar
Yes, it has VVT.
If you bought a 3 bolt cam, you'll need a 3 bolt cam gear, different timing cover among other things to make it work.
Old Feb 28, 2016 | 05:53 PM
Wolftrk99's Avatar
Yes you have vvt, 2 options, get vvt and the phase limiter from comp or go without vvt and get a cam designed for ls3 style heads.... Check your casting numbers on the heads im sure you have 823 or 0821 casting, which are rectangular port heads.... And a cam designed for cathedral port heads will leave you scratching your head and disappointed...
Old Feb 28, 2016 | 06:06 PM
lopy6oh's Avatar
Originally Posted by FFDP
Yes, it has VVT.
I do recall texas speed saying something like this before confirming with the dealer about vvt. I guess I'll be ordering more parts
Old Feb 28, 2016 | 06:08 PM
Wolftrk99's Avatar
Id return the cam, and get either a vvt cam and phase limiter or delete vvt and get a can designed for the rectangular heads and plan on a stall too
Old Feb 28, 2016 | 06:09 PM
lopy6oh's Avatar
The only thing I see on the heads is c232. With my 3 bolt cam I purchased I'm assuming the phase limiter won't work. Will these heads be ok with this cam?
Old Feb 28, 2016 | 06:14 PM
lopy6oh's Avatar
Well after talking with texas speed, I went with the 220r 112 lsa instead of the 224r 112lsa because I could keep the stock converter for now (according to them anyway). I was trying to go for somewhat of a budget swap but it never seems to work out that way.
Old Feb 28, 2016 | 06:24 PM
Wolftrk99's Avatar
Look on the corner below the valve cover bhind the alternator... Something like this....
Old Feb 28, 2016 | 06:35 PM
lopy6oh's Avatar
ok I got it now. Yes they're 823 heads. So my cam isn't designed for rectangular heads or is that something I'd have to ask tsp?
Old Feb 28, 2016 | 06:50 PM
Wolftrk99's Avatar
What are specs on it??
