LY6 402 LS3 CNC Heads and Cam
Old Feb 28, 2014 | 10:17 PM
Raul_Chile's Avatar
Default LY6 402 LS3 CNC Heads and Cam
Hi, please your opinion about my new LY6 Stroker
My current set up consist of:
6.0 LY6 - LS3 CNC heads, Arp Studs (Bottom stock)
Comp Cams 156-403 222/236 114LSA
T56 tranny + D20 Transfer Case
D44 Front - F9 Rear
340 Aeromotive in tank & 30# injectors
4.11 Gears - Detroit rear locker
Wrangler TJ 1999
If I go 402 I will
TSP 402 C.I.D. LY6 Rotating Assembly with optional Lunati forged crankshaft and connecting rod
LS3 CNC heads (pushrod, valve and springs stock)
Wiseco pistons -20cc dish
Manley Pro-Flo Oil Pumps
340 Aeromotive in tank & 72# injectors
RC 9,25:1
HpTuner tune in home
Regards
Old Mar 1, 2014 | 06:14 AM
53bowtie's Avatar
Looks like a solid plan. If there are no plans for boost in the future I would shoot for a buy more compression. The stock engines run on 87 octane just fine at 9.5-10:1 compression and if you have good higher octane fuel you may be able to go a bit higher than that.
Old Mar 1, 2014 | 11:20 AM
Raul_Chile's Avatar
We have 97 octane but with compression over 9.5:1 we have problems exhaust temperatura control. I climb up on sand hills by 400 to 700 meters on Atacama Desert
My plan the next year is go for boost(sure change RC 8.0:1 aprox)
Example video in Desert Trophy - Summer Games 2014
Summer Games 2014 - La Luca Pro - YouTube
This is my Jeep (testing)
Primera Bajada diablo sin vuelo 2 - YouTube
Regards
Raul
Old Mar 2, 2014 | 08:37 AM
tashspop's Avatar
sweet, that looks like a blast
Old Mar 2, 2014 | 11:17 AM
69Camaro427's Avatar
Yeah, I don't think high compression will like that heat or hill grade lol
Old Mar 10, 2014 | 08:25 PM
Raul_Chile's Avatar
Help please with choice
http://www.summitracing.com/dom/part...make/chevrolet
Melling Performance Oil Pumps 10296
Old Dec 3, 2014 | 10:16 PM
Raul_Chile's Avatar
Hi, I installed the stroker with the new camshaft and GM VVT phaser limiter, but this cam has ICL 111(LSA114) and I used phaser with limiter nothing else, so I“m looking for a timing set to correct cam perfect instalation.
Regards
Raśl
Old Feb 18, 2017 | 09:49 PM
Raul_Chile's Avatar
ufff....so long time
Attach many pictures and videos
Attached Thumbnails LY6 402 LS3 CNC Heads and Cam-_dsc0123.jpg   LY6 402 LS3 CNC Heads and Cam-_dsc0057.jpg   LY6 402 LS3 CNC Heads and Cam-tj-60hrs.jpg   LY6 402 LS3 CNC Heads and Cam-lsx.jpg
Old Feb 18, 2017 | 09:53 PM
Raul_Chile's Avatar
Old Feb 18, 2017 | 09:54 PM
Raul_Chile's Avatar
