ls7 lifters ques...
Old Sep 1, 2009 | 02:46 AM
lucky77's Avatar
Banned
Default ls7 lifters ques...
im gonna be putting my engine back together pretty soon.... IM gonna be running ls7 lifters/ I'ver been reading that, these lifters require a shorter pushrod? is that right?
or will my 7.4 be fine?
any-b has done this swap before, what size of pushrod , are you all using?
Old Sep 1, 2009 | 02:57 AM
2005 Silverado's Avatar
SPAM HUNTER
Im in the same boat as you. I am just going to get the pushrod checking tool to get the actual distant then add the preload and have them made. Even if some guys have used a set length it can be wrong for your motor.
Dustin
Old Sep 1, 2009 | 08:19 AM
Tootall's Avatar
the LS7s have a smaller "cup" than the LS2 or newer style lifters . . .
There's a thread on it on tech about measurements and detentions of both.
Old Sep 2, 2009 | 08:50 AM
03 BLACKOUTSSS's Avatar
The LS7s are reportedly .050 taller than the older style lifter. I don't know when they stopped using the older style lifter though. I just did a H/C swap and I am now using 7.300 PRs. I dropped my head gasket thickness by .010 and installed the LS7s. 7.300 got me .050 preload.
Old Sep 2, 2009 | 08:51 AM
what year is your truck? If its the truck in the sig, you probably have LS7s in there. Its my understanding that when GM switched, all V8s got the LS7s, but you'd have to verify that.
Old Sep 2, 2009 | 11:42 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
They have a smaller cup, shorter travel and require different preload. Stick with the CTSVs.
Old Sep 2, 2009 | 09:17 PM
budhayes3's Avatar
PT's Slowest Truck
What's a CTSV? Are you referring to Caddy lifters?
Old Sep 2, 2009 | 11:30 PM
lucky77's Avatar
Banned
mine came with DOD lifters and the lifter guide is a bit different.. than the ls2 lifter guides
Old Sep 2, 2009 | 11:38 PM
lablackbeast's Avatar
doesn't know what quit means
do 6.2s come with ls7 lifters already??????...
Old Sep 3, 2009 | 08:14 AM
silveradokidd_4518's Avatar
yes he is refering to the Caddy lifters...
and i have also read that if you are using LS7 lifters you need to use the 7.35 pushrods...
