LS6 springs
Old Jun 15, 2011 | 09:00 AM
  #21
andrew383's Avatar
traveling mod
Well to spark this discussion back up..I picked up a set of ls9 springs from Lingenfelter and they said there rated at .580 lift...They are blue also
Old Jun 15, 2011 | 10:05 AM
  #22
TX Tahoe Z71's Avatar
Originally Posted by andrew383
To further excite this discussion Lingenfelter GT2-3 cam comes with a set of yellows..
207/220 .571/.578 118.5
I have a cam thats going in the tahoe thats a 208/214 .551/.561 112 that im going to run yellows on but it will shift at 6k max and its the wifes DD...
The LS6 springs better be good on the GT2-3 because that's what is going in soon (hopefully this weekend, fingers crossed)
Old Jun 15, 2011 | 11:44 AM
  #23
budhayes3's Avatar
PT's Slowest Truck
So I'm guessing that "LS9" springs are the new GM "performance" valve spring, or LS6,2,3,9 whatever, use the same spring...I wonder if they all carry the same part number
Old Jun 15, 2011 | 12:57 PM
  #24
Talked with a tech at Lingenfelter today and he said the LS6 springs are discontinued, but they use "matched" LS9 springs now for the GT2-3 cams; matched, he explained, means measuring spring height to ensure they are tall enough, then putting those 16 together as a package. Apparently the LS9 springs are sometimes different sizes.
Old Jun 15, 2011 | 01:17 PM
  #25
Sales2@Texas-speed's Avatar
Former Vendor
If the new blue LS6 springs I measured are the "LS9" spring, you don't want anywhere near .580" valve lift on them! TERRIBLE idea!
Old Jun 15, 2011 | 02:05 PM
  #26
Using the yellow ones, and after reading this thread, feel much better about it.
Old Jun 16, 2011 | 10:46 PM
  #27
andrew383's Avatar
traveling mod
The LS9 camshaft is 211/230 .558/.552 122.5
The GT2-3 is 207 / 220 .571/.578 118.5
They sell the gt2-3 with ls6/9 springs..
Not saying your right or wrong Matt but it is what it is and they have a pretty good rep with there builds..
Like i said before the next cam im installing is almost the same lift as the ls9 cam and im sure that vette will run a solid 200k miles on the stock springs
Old Jun 17, 2011 | 07:57 AM
  #28
beingblueeyes's Avatar
whats the ls9 spring installed height? and whats it coil bind @?
Old Jun 17, 2011 | 09:21 AM
  #29
Beau@SDPC's Avatar
Trucks Sponsor
Yes and Yes. LS2/3/6/9 are all the same number.
Old Jun 20, 2011 | 08:55 AM
  #30
budhayes3's Avatar
PT's Slowest Truck
Cool deal, thanks for the info Beau!
