LS6 springs
Old May 2, 2011 | 02:43 PM
Suddog's Avatar
OK, that is the info that I'm familiar with, the blues are good to .529 (I knew that it was less than .530), and the yellows are good to anywhere from .550 to .580, depending on who you talk to. They have to be good to over .550 as the 02-04 LS6 cam had .551 lift...
Billy, I can confirm that they are good up to .529 lift cause that is the lift of my cam now...
Glad to know that I got the right springs.
No cool little "Made in Germany" stickers though...
Old May 2, 2011 | 04:10 PM
Sales2@Texas-speed's Avatar
Former Vendor
Just curious, do they still come with the little blue "Made in Germany" tags on them?
Not seeing that.
Old May 3, 2011 | 07:36 AM
budhayes3's Avatar
PT's Slowest Truck
Hmmm, makes me wonder if GM is getting them from a different supplier now then, of if the company that makes them is just trying to save a few bucks on little tags lol.
Old May 3, 2011 | 11:02 AM
Former Vendor
I just tested pressures.
Yellow:
1.800" ~ 90lbs
1.250" ~ 290lbs
Blue:
1.800" ~ 95lbs
1.250 ~ 300lbs
The blue spring seems to coil-bind even taller than the yellow springs do also, so whatever the yellow's max lift was rated for, the blue should be lower.
For what it's worth, I think you'd be crazy to run either spring anywhere near .570" lift! They just don't have the coil bind, or pressure, to run anything very aggressive on, and you still see stock LS6 cammed setups with stock rockers experiencing valve float because of these springs.
For performance applications, run a performance spring!
Old May 3, 2011 | 01:23 PM
budhayes3's Avatar
PT's Slowest Truck
Yellow:
1.800" ~ 90lbs
1.250" ~ 290lbs
Blue:
1.800" ~ 95lbs
1.250 ~ 300lbs
Good info Matt, thanks again!
Old May 6, 2011 | 11:29 PM
NextLevel's Avatar
Thanks for testing things Matt, I'm not going to be running anything over .540 lift in my 5.3 4x4 anyway and don't want a noisy valve train so I think the blues will work just fine. Thanks again for testing those springs, it helps me and I'm sure it will help someone in the future using the search button.
Old May 7, 2011 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
What's a search button?
Old May 7, 2011 | 09:27 PM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by matt@texas-speed
for performance applications, run a performance spring!
pac ftmfw!!!!
Old May 8, 2011 | 08:13 PM
andrew383's Avatar
traveling mod
To further excite this discussion Lingenfelter GT2-3 cam comes with a set of yellows..
207/220 .571/.578 118.5
I have a cam thats going in the tahoe thats a 208/214 .551/.561 112 that im going to run yellows on but it will shift at 6k max and its the wifes DD...
Old May 9, 2011 | 12:17 AM
budhayes3's Avatar
PT's Slowest Truck
Yessir...and I haven't heard of too many failures with them either. IIRC, a bunch of guys over at SilvySS.com run the Lingenfelter GT cams and springs with good results
