ls6 cam on a 5.3???
Old Jan 23, 2010 | 03:36 PM
  #21
rubrhammer's Avatar
FWIW Gm uses 7.4 pushrods on the 234 heads with longer valves. I personally would run a longer pushrod if I'm not running the LS6 length valves but 7.4 if Using the long valve. I can see GM keeping things simple with 1 PR length and I do believe that they tested the LS6 extensively before releasing it for production.
Bob
Old Feb 3, 2010 | 02:02 AM
  #22
LTX355's Avatar
I was also wondering what gains 02+ ls6 cam offers as one of my buddies is looking for a sleeper cam for his 5.3
Old Feb 3, 2010 | 02:08 AM
  #23
RandomHero's Avatar
I'm fixing to do this swap hopefully within the week. If all goes as planned I'll let you know my results.
Old Feb 3, 2010 | 02:14 AM
  #24
LTX355's Avatar
Thats kool... Ive done plenty of searching and not many have listed any actual number gains. only thing i have heard is something like 20hp above 4k or so... and a slight decrease in low end compared to stock cam...
Old Feb 3, 2010 | 11:19 AM
  #25
smokeshow's Avatar
Mod with training wheels
I can agree with that...that's about what my results were with a similar cam.
Old Feb 3, 2010 | 11:41 AM
  #26
RandomHero's Avatar
Oh I forgot to mention, i'll be stepping down from a 224/224 on 112 comp cam. I'm doing the swap in preparation for a turbo setup. I'll let you know on the power loss.
Old Feb 3, 2010 | 12:54 PM
  #27
ItsNotaNova's Avatar
Are there any differance in the LS6 cams year wise, thanks Justin
Old Feb 3, 2010 | 12:57 PM
  #28
LTX355's Avatar
I would imagine a decent loss from the 224 cam. Did you ever dyno with the 224?
Old Feb 3, 2010 | 01:00 PM
  #29
LTX355's Avatar
from what i have searched yes. 01 ls6 cam is a 204/211-.525 lift with i wanna say a 116lsa and 02+ ls6 cam is 204/218 with like .550 lift and 117.5 lsa.. my numbers maybe off just a bit as im just pulling them from what i remeber.
Old Feb 3, 2010 | 10:01 PM
  #30
Rick_Vor's Avatar
Pretty close...
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
Rick
