ls6 cam on a 5.3???
#21
FWIW Gm uses 7.4 pushrods on the 234 heads with longer valves. I personally would run a longer pushrod if I'm not running the LS6 length valves but 7.4 if Using the long valve. I can see GM keeping things simple with 1 PR length and I do believe that they tested the LS6 extensively before releasing it for production.
Bob
Bob
#24
Thats kool... Ive done plenty of searching and not many have listed any actual number gains. only thing i have heard is something like 20hp above 4k or so... and a slight decrease in low end compared to stock cam...
#25
I can agree with that...that's about what my results were with a similar cam.
#28
#29
from what i have searched yes. 01 ls6 cam is a 204/211-.525 lift with i wanna say a 116lsa and 02+ ls6 cam is 204/218 with like .550 lift and 117.5 lsa.. my numbers maybe off just a bit as im just pulling them from what i remeber.
#30
Pretty close...
LS1 Camshaft Specifications
1998 - 2000 Fbody
202/210 int/exh @ 0.05" duration
0.496" / 0.496" int/exh lift
116 LSA
2001 - 2002 Fbody
197/207 int/exh @ 0.05" duration
0.467" / 0.479" int/exh lift
116 LSA
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
GMPP Hot Cam
218/227 int/exh @ 0.05" duration
112 LSA
GMPP ASA Cam
226/236 int/exh @ 0.05" duration
110 LSA
6.0 LQ9
207/196 int/exh @ 0.05" duration
0.479" / 0.467" int/exh lift
116 LSA
5.3 LM7
190/191 int/exh @ 0.05" duration
0.466" / 0.457" int/exh lift
114 LSA
Rick
1998 - 2000 Fbody
116 LSA
2001 - 2002 Fbody
116 LSA
2001 LS6 cam
116 LSA
2002+ LS6 cam
117 LSA
GMPP Hot Cam
112 LSA
GMPP ASA Cam
110 LSA
6.0 LQ9
116 LSA
5.3 LM7
114 LSA
Rick
