LS1 heads on 5.3
Old Jul 2, 2007 | 09:28 AM
1989k1500's Avatar
Default LS1 heads on 5.3
If I got LS1 heads and had em mileld down a little to lower the compression back down to stock would thses be a good head to run or should I stick with the stock 5.3 heads?
And if I went with the ls1 heads the truck intake could still be used correct?
Old Jul 2, 2007 | 11:35 AM
nighthawk08's Avatar
i think they flow about the same as 5.3 heads
Old Jul 2, 2007 | 01:22 PM
TarheelZ's Avatar
You're gonna have issues with the valves being shrouded if you use the LS1 heads. Your stock heads flow pretty well but can be improved somewhat by a mild pocket port job. Good luck!
Old Jul 2, 2007 | 10:01 PM
1989k1500's Avatar
Ive heard that but I was making sure, my friend has a spare set of ls1 heads and I figured theyd flow a lot better.
Im gunna stick with the 5.3 heads then.
Thanks guys.
Denali08
Aug 9, 2015 04:34 PM
vmaxpro
Aug 4, 2015 07:02 AM
steves86ta
Jul 28, 2015 10:21 AM
vmaxpro
Jul 27, 2015 10:45 PM
Black-Syde
Jul 6, 2015 02:12 PM
