Build Around Swirl Port Heads!
Has anyone had any good luck adding mods like Cam, Springs, Rockers, Larger TBI, Intake, headers and so on, but left the stock swirl port heads on the truck and just added better parts ie: springs, rockers ect.?
I'm in a performance bind, I have enough money to add a good cam, lifters, springs, timing set, 1.6 roller rockers, underdrive pullies, and a good intake manifold. I don't have enough cash right now for a good set of heads.
I've heard the Swirl Port heads are ok to 5500 rpm but fall off the chart after that. I've gone as far as I can with a custom tune, exhaust, cold air intake, tranny mods, larger TBI and injectors, etc. But I'm still way to slow. I know the cam will help a ton.
So has anyone else built around the stock 88-95 swirlie heads and still made descent power?
i am sure many people have done it but why get new rockers? the ones from the factory are good enough so that should free up some extra money.....also you dont have to spend big bucks for heads, take your stockers and port them yourself and you should be good, wouldnt do much good to get a cam that pulls higher than 5500 if your heads dont flow good past that, make sure you match the two.......
The swirl heads are good for nothing but gas mileage. Intake airflow is awful with those heads. Unless your are a real good head porter and are willing to do a lot of work for free you're better off with a set of non swirl stock heads. Try Alabama Cylinder Heads (Patriot's parent company) to see what deals they have on a pair of heads.
Good luck with your build.
Richard
Richard
[[/url]
[[/url]
I had swirl port heads on a 350 tbi i built a while back. I swapped them out for a pair of 350 tpi heads from a camaro and it made quite a big difference. I picked them up for $50 so you don't have to spend alot on heads.
So the TPI Camaro heads will bolt right on? Do you know what year the heads were off of, part numbers are any info. If that works that would be awsume! I could swing maybe $100 on heads but not any more, right now. Thanks.
Your best bet is to go with the vortec heads. I think they are about $600 a set maybe cheaper used. They're worth 30hp alone. I built a 383 tbi with the swirl heads. It had ridiculous tourque but laid down at 5k. I'd say either get them now, or wait. The tpi heads aren't enough different to really do that much. As for do it yourself porting, theres a little more to it than just hogging out the ports. The only do-it-yourself porting I recomend is gasket matching.
