LS help needed in regards to Cam and tune
Old Nov 17, 2017 | 07:04 PM
  #31
Samuel-Jenie Boyd's Avatar
Originally Posted by Atomic
An easier way to doing a "flood clear" is hold the gas pedal to the floor while cranking. This will disable the injectors during cranking.
It is relatively difficult to hurt a stock engine by running too lean without a power adder. Actually "lean" is fine, right at stoich is the most dangerous because it is the hottest. Keep in mind stock tuning has a 60s delay and a 5000rpm delay before it will give extra fuel.
The plugs look very rich. You need tuning
Thank you for the info. I have noticed that delay you speak of, never did before the cam though. Will the cutom tune get rid of that? Its sceduled for tuesday. I cant stinking wait!!
Old Nov 17, 2017 | 08:08 PM
  #32
Atomic's Avatar
I have a gauge for that
Yes, your tuner should fix that. If you want to get your own interface and/or want someone to tune it remotely for you so you can learn let me know and I will get you taken care of
Old Nov 17, 2017 | 09:06 PM
  #33
Very kind of you, thank you. I will let you know when i open that bag of worms
Old Nov 21, 2017 | 08:07 AM
  #34
At the tuning shop now.. 350 HP was the goal. Wish me luck :p
Old Nov 21, 2017 | 08:25 AM
  #35
About20ninj45's Avatar
good luck
Old Nov 21, 2017 | 08:41 AM
  #36
darkirish63's Avatar
post your progress - hope everything works out well.
  #37
madmann26's Avatar
Originally Posted by About20ninj45
good luck
Ditto.
With a 4.8 and the cam you chose, it will be hard.
That cam will need to see around 6800rpm or so to make max power.
Old Nov 21, 2017 | 09:14 AM
  #38
Atomic's Avatar
Dont blow it up!
Old Nov 21, 2017 | 10:38 AM
  #39
Ahh, we will have to wait for the results. The tuner will not allow me to dyno it with my stock pushrods. #1 they are to short, #2 they are weak
I know, i should have known better, but my budget couldnt support it at the time. In the grand scheme of things i am glad though because i would have just got 7.4" pushrods not knowing any better. With that being said, do you guys know a good/cheap place to find quality 7.425" pushrods?
Old Nov 21, 2017 | 10:49 AM
  #40
turboal1's Avatar
Default Push rods
BT sells them at a decent price, I bought mine
from them, can't remember the price, was a while ago.
go to there web site.
