LS help needed in regards to Cam and tune
Samuel-Jenie Boyd (11-15-2017)
Thank you tons, i will try this now.
I dropped it off at the exhaust shop running fine then picked it up with this issue. I can only assume they cranked it a ton without giving it some gas pedal(which it needs to get going with this new cam). I failed to inform them but i assumed they would know how to handle those kind of situations. I guess what they say about making assumptions make an *** out of you and me is true.
Is it possible that damage could have been done due to this extreme case of flooding
I cranked and cranked with the relay out and pulled a plug, still soaked. I pulled all the plugs now and i am just gonna let her set overnight. I will re-adjure the problem tomorrow night, hopefully all that stuff clears out of the cylinders by then.
Do you think something could have been damaged in the process?
I know the audio of the chop may have sounded cool but it didn't sound "healthy" if that makes sense. What is the lsa on that cam, by the way? Regardless - don't try and start the thing again until an experienced tuner can take a stab at it - let the board know...curious to know if you didn't torch something or not.
