LS help needed in regards to Cam and tune
#51
Without seeing the tune it's hard to comment of why it's doing the open/closed loop switch like that at idle. That 2000 OS has all the tables he needs to tune just a cam setup, knowing how to tune the VE and MAF properly on the early 99-00 OS is key. The 01's does have a few more tables and a few less tables that make it easier is some aspects but it's not a must to have.
#53
Thank you for that, i will def ask him to give that a shot. Will that be really hard on the trans?
I will see if he would be willing to give me a copy of the tune.
I have some ls6 springs, hardened pushrods, and the new valve spring keeper do dads inthe mail right now. Is it really nessasary to replace the spring retainers? I know i should but i also know i am spending more loot then i should be right now. How important are the retainers in the grand scheme of things?
#54
One more thing i wanted to ask about. My tuner advised against installing my transgo shift kit. He said the Vette servo is almost a must and the shift kit is just a waste.
What are your thoughts on this opinion? Would you guys agree or disagree with this assessment and why?
#57
Ok next question; so i am putting in my pushrods and valve springs and noticed that some of my old pushrods were wore down more then others. Is this an indication of a problem? What could this mean?
#60
No split duration or lift. It was just on 2 or 3 in one bank and where i noticed it was where they made contact with the rockers not the lifters. Idk it just seemed odd to me because when i installed the cam all the pushrods were wore evenly and not now.
