LQ9 C3500 swap
Old Jan 12, 2021 | 10:08 PM
MRFLORIDA's Avatar
Default LQ9 C3500 swap
Hello all, I'm new here not just this forum but to the LS world as well. I have a 1991 c3500 dually that I want to put this lq9 out of an 06 escalade equipped with the DBW throttle body. I also managed to find a 4l80e transmission out of a 2003 chevy 2500 both engine and tranny have under 100,000k on them I plan to use the stock converter. I purchased the correct flexplate from summitracing with the built in spacer and came with the bolts as well. I am wanting to do a simple cam swap but don't know 🤔 which cam to buy or what would best suit my application a healthy lope wouldn't hurt either. I purchased Holley Terminator X Max Efi to run both the tranny and engine. Should I also be looking for a specific fuel pump? Thanks in advance.
Old Jan 12, 2021 | 10:17 PM
FFDP's Avatar
A standard Walbro 255lph pump would be plenty with a good pressure regulator.
Stock converter means smaller camshaft. Like 212/218 size, I bet most places have that as a "stage 2" or something.
Don't forget about fuel injectors. I don't know what you have right now or what that 6.0 came with. Some factory injectors are 25lb/hr and others are 33's if the truck was flex fuel, the larger ones would handle a cammed 6.0 no problem.
Old Jan 13, 2021 | 06:33 AM
MRFLORIDA's Avatar
Preciate it FFDP. The fuel pump you mention above is that an internal or external, if I upgraded the stall on the trans in your opinion is a worth it what kind or gain would I expect. I have a buddy running this cam ( comp cam link) https://www.compcams.com/cam-dynamic...en-iii-iv.html
makes great power but I'm not trying to reinvent the wheel so to speak just looking for a little giddy up. Thanks again bud
Old Jan 13, 2021 | 06:42 AM
wretched73's Avatar
I doubt you would enjoy that cam in your truck
I run a 212/218 112 LSA in my 6.0 swapped 1500. I'd recommend it to anyone
Old Jan 13, 2021 | 12:23 PM
Summitracing's Avatar
LS1Tech Sponsor
What's the intended use and goals you have for the truck? This will help with cam recommendations.
Old Jan 13, 2021 | 01:18 PM
RedXray's Avatar
100% Redneck
Yeah that cam is huge for a heavy dually truck. You need something smaller that doesn't sacrifice bottom end torque for high RPM's.l
Old Jan 13, 2021 | 04:01 PM
MRFLORIDA's Avatar
Summitracing The truck will be used for towing/pulling its mainly a workhorse. Thanks in advance
Old Jan 13, 2021 | 05:25 PM
pcmcobra's Avatar
head over to 67-72trucks forum, been done a kajillion times a kajillion ways. Plenty of build threads to follow and get info from.
I've done 2 squarebody ls swaps, both different animals.
Old Jan 13, 2021 | 05:30 PM
00pooterSS's Avatar
If you're going to be doing a lot of towing and pulling the stock converter and cam are generally the best.
A tiny torque cam would be okay, but won't make a ton of difference. I'd probably put that money into gears instead.
Old Jan 14, 2021 | 11:24 AM
LS1Tech Sponsor
Pooter pretty much nailed it. For what you're going to be using this for the stock cam is probably best. Gears, headers, and a free-flowing exhaust could be of equal benefit or even more than a cam swap for what you'll be doing. If anything a stage 1 tow/torque cam could be of good use. Any of those style cams aren't going to have a lopey idle that you mentioned you wouldn't mind having.
If you wanted to look into cams something like our Pro LS Truck stage 1 tow cam would be a good one to look at. That is part number SUM-8718R1. Specs on it are .500/.500, 205/217, 112+2. The intake valve closing point is a good indicator of where you can expect the powerband to be. The stock cam for an LQ9 closes the intake valve 34* ABDC. The 8718 closes the intake 33* ABDC. In general the earlier you close the intake valve the lower the powerband will start. A nice thing about this cam is it can be used as a drop-in. That means no springs required. We do recommend budget-friendly LS6 , rings. We offer them in our own brand as part number SUM-174002.
Another tow/torque cam we'd recommend is the BTR torque cam. That is part number BTC-30202111R1. Specs on it are .511/.511, 202/202, 111+1. This closes the intake valve 31* ABDC. BTR does recommend LS6 style springs for this cam. You could use our springs above or BTR offers their own LS6 style springs as part number BTC-SP011-16.
You could even look at our Pro LS Truck stage 1 high lift cam. That is part number SUM-8719R1. Specs on it are .550/.550, 209/217, 112+1. The added lift over the two other cams will improve power and torque. Between the added lift and earlier intake opening, more low-end torque will be made. With the idle speed turned down you could get a bit of a lope out of it. The LS6 style springs would be a requirement with this cam.
As a reference, the stock cam specs for an LQ9 are .467/.479, 196/201, 116.
