LQ9 6.0 Build with GEN4 Cam Conversion Question/Help?
Old Oct 30, 2012 | 09:29 PM
DTSNGIT's Avatar
Default LQ9 6.0 Build with GEN4 Cam Conversion Question/Help?
I want to put a ZR1 GEN4 Blower Cam in my 2004 Silverado 6.0. I know I will need to do a GEN4 conversion but not quite sure what all will need to be changed.
Has anyone done this conversion?
Obviously I have the cam already. From what I've read I will need a LS2 Timing Cover with Front mount Cam Position Sensor, LS2 Valley Cover, and I believe the LS2 Timing Gear plus an extension harness to plug the Cam Position Sensor in the front cover.
Or would I just re-use the trucks old Timing Gear?
Old Oct 30, 2012 | 10:10 PM
1Bear's Avatar
You’ve got most of it covered with your ideas of what’s needed, but a couple of things are off, such as you would use your stock valley cover (LS2 won’t fit a Gen III) and a 1X cam gear that matches the 24X crank reluctor wheel for use with your stock PCM.
Old Oct 31, 2012 | 12:35 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
If you know the specs that you want, you can always get a camshaft custom ground to match those specs and match your setup. We offer our custom grinds for $399.99. Just an alternative to having to swap a bunch of items over.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Aboss
Jul 9, 2015 10:28 AM
