lq4 pistons to -4cc mahle flat top questions
Old Nov 2, 2007 | 08:30 PM
dirt track racer 81's Avatar
Default lq4 pistons to -4cc mahle flat top questions
how much gain would i be getting in compression going from a lq4 piston to a -4cc mahle flat top piston..roughly how much hp gain is this..how big of a shot would this be able to handle?? thinking 225-250..possibly more?
Old Nov 2, 2007 | 08:40 PM
Derek @ EDO's Avatar
FormerVendor
the only concern would be the rods, Im sure it would hold that progressively controlled
Old Nov 2, 2007 | 08:55 PM
gettin h-beam 6.125..and the heads are ported ls1's with a 66cc chamber and using either .030 or .040 cometic head gaskets
Old Nov 2, 2007 | 09:32 PM
Wilde Racing's Avatar
How do I change this text
Which casting? 2618 or 4032
Old Nov 2, 2007 | 10:05 PM
Compression comes out to 10.062 ish... I think, someone with a clue might want to double check me....
Old Nov 3, 2007 | 04:14 PM
4032..which one is better
Old Nov 3, 2007 | 05:08 PM
In very short form...
2618 = Very strong, will take allot of pressure, shorter life, I have heard they tend to ratle a bit more, because of the extra clearince need to run them
4032 = Not as strong, but longer life, also quiter
Old Nov 3, 2007 | 05:36 PM
how much do you think i could spray them?
Old Nov 3, 2007 | 06:35 PM
I have no idea. all the research I've done makes the 4032 sound like a slightly stronger than stock piston, so I'll be running the 2618's in my engine. check out LS1tech side, there is A TON of info on pistons over there.
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
