lq4/lq9
Old Apr 29, 2008 | 09:39 PM
Parke10's Avatar
Default lq4/lq9
i know i should know this by now and either i cant search the right terms, search feature blows,or im blind because i know this has be discussed countless times but.....
Every difference between the LQ4 and LQ9, the only one i know of is comp ratio
what else? heads? cam? valves? anything and everything
Thanks in advance
Old Apr 29, 2008 | 09:41 PM
moregrip's Avatar
what a rush!
used to be the connecting rods were slightly different, but as of 05 I think they all used the LS2 style conrod.
Old Apr 29, 2008 | 09:56 PM
Parke10's Avatar
cuz im tired of lookin for a complete lq9 and when i do find one its either so far away that itll kill me in shipping or expensive as hell, or both
Old Apr 29, 2008 | 09:57 PM
InchUp's Avatar
Some LQ4's had iron heads and a longer crankshaft. I also found that at one point GM stuffed the same 5.3L/4.8L camshaft into the early LQ4's which kinda pisses me off but oh well. Now the LQ9 has a higher lift on the intake side of the cam to help it breathe better up top.
Old Apr 30, 2008 | 12:38 AM
Parke10's Avatar
anymore?
Old Apr 30, 2008 | 03:17 AM
PappyDan's Avatar
Tribe Shaman
if you buy a 6.0 block, rip the head off and see,
a flat top piston it is an LQ9.
a dish piston then it is an LQ4.
Old Apr 30, 2008 | 12:26 PM
Zick's Avatar
Heads are the same, cam I believe is slightly different and not worth worrying about. Rods were different up till 05' like Moregrip said.
Pistons are dished on LQ4 and Flat top on LQ9
The early 99-00's are the ones that came w/ iron heads and longer crank shaft flange. Steer clear of them.
Never heard of the LQ4 getting a 4.8/5.3 crank.
Old Apr 30, 2008 | 01:07 PM
TouchOfEvil04's Avatar
Arn't the lq9 pistons a little stronger as well? Or is that just unproved forum talk?
Old Apr 30, 2008 | 02:04 PM
Parke10's Avatar
so if im gonna rip it apart and build it up, is there really any reason to get a lq9 over an
lq4?
Old Apr 30, 2008 | 03:57 PM
Parke10's Avatar
also, i know nitrous likes high comp ratios and boost likes low, wont nitrous be okay on a lq4 since its not that low of a comp ratio?
