Looking for specs on engine. 2000 chevy silverado ext. cab 4X4
Old Oct 28, 2006 | 11:04 AM
cadmafa's Avatar
Default Looking for specs on engine. 2000 chevy silverado ext. cab 4X4
I just got the truck, so I don't know too much about it. Its a 2000 silverado ext. cab 4x4, with the 5.3 vortec. I would like to know the stock cam specs, heads, and valve size. Right now the truck is completely stock except a magnaflox muffler. I do alot of off roading, so what do you guys recommend for bolt on's, possibly a cam swap, chips, any help would be nice! Thanks for your time.
Old Oct 28, 2006 | 06:47 PM
cadmafa's Avatar
Any help would be nice....im just looking for some performance upgrades that won't cut inot my wallet too much. I have about 1200 bucks to blow....?
Old Oct 28, 2006 | 06:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
If you do a lot of off road then you might look at gear change, locking differential and getting a good tune.
Old Oct 28, 2006 | 07:02 PM
cadmafa's Avatar
what are some cheaper upgrades for engine performance....? 1200 to spend. I have already put a fabtech 4inch lift on, with 33'' 12.50s. Gear changes are in the near future...im open to any ideas. Thanks
Old Oct 28, 2006 | 07:05 PM
trever1t's Avatar
I would do the gear change first. you should have 4.10's at least, 4.56 even better. That will run around $1000
Old Oct 28, 2006 | 07:10 PM
nightrunner's Avatar
Mr. Obvious
gears
tune
exhaust
headers
cold-air intake
cam swap - something like a tr220 and comp918 springs
WCCCH 5.3 cylinder heads
in this order
Old Oct 28, 2006 | 07:37 PM
i dont know about a 220 with his lift and offroading desires....he'd be better off with a 212/218 highlift or something
Old Oct 28, 2006 | 07:42 PM
Mr. Obvious
i dont really know much about cams it just seems like a pretty common mild-moderate cam around here
Old Oct 28, 2006 | 08:11 PM
Keith's Avatar
comp's 206/212 on a 112 would be a good small cam to go with.
Old Oct 28, 2006 | 08:32 PM
yea its common but a lift and 33's arent. plus he would need a stall with that and thats not optimal for offroad
B.love18
Sep 21, 2015 08:31 PM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
Suburban2500
Jul 19, 2015 04:50 PM
ALynch
Jul 6, 2015 09:49 AM
Nimoryan
Jul 5, 2015 03:50 PM
