Look!! Cam question
Not all circle d's are budget converters, the one bud was talking about (which I am also running and I really like it) is a budget converter and is $375 shipped for members. Bud beat me too it, I dd the same stall as mentioned with a tsp 224r and some 4.10s. Great combo imo. I reccomend the op runs at least the 26-2800 circle d 278mm but the 3200 will be more agressive and optimal for a cam of that duration imo
I like your combo 06Sierra2, sounds like a well matched setup IMO
Originally Posted by 06Sierra2
a stall doesnt give you more hp as you may already know, but it will def. drop some et's and make your truck feel stronger on the street as well. with my cam and stall i gained about a whole second in the 1/4 (after tuning). I think tsp advertises some where around 35hp peak gain for that cam? it will require tuning of course...
Besides what has already been mentioned about aftermarket stall converters; while converters come in all sorts of specifications, most of the performance converters for gasoline applications will usually also be of a smaller diameter and different materials resulting in a significant weight loss, which can result in a quicker revving engine, all other things being equal.
But take note that I used the words “most and can”, as this is not always true, yet whatever the case you don’t necessarily want to go out and purchase the smallest diameter/lightest weight converter you can find, as again while all converters are not created equal, usually you will take a hit of some degree in slow speed efficiency the smaller they get.
The main thing is to speak with the manufacturer of choice and give them the specifications of your combination and your desired expectations, to let them recommend a particular unit. They do have the ability to loosen or tighten up a converter a certain amount in any given size unit and if what you’re ultimately looking for exceeds what they can do, they will recommend that you look for a different part.
bbowerman
Jul 26, 2015 10:57 PM
