Long life turbo 6.0, (or 408)
How do I change this text
So my 6.0 is stock exept the 918 spring and I know it will kick the bucket someday, so what does everyone think is important for a long life boosted engine making over 500 rwhp?
IMO you want to go upgrade the strength to forged / hardened.
If you are going there, you might as well have the block checked / cleaned up while its out.
Since you already have the block in the machine shop, you might as well punch it out
I'd do a nice forged 408 -- you probably want to step up the turbo at the point. You'll be able to spec exactly what you want in terms of CR and target your boost / power level. 8.6:1 is great for high boost, but 9:1 will work, and 9.5:1 if you're gonna keep the boost at 12 or so.
I'd go for diamond pistons again and a callies racemaster crank, but that's just my preference. Plenty of folks make good FI pistons. I wouldn't skimp on the crank or rods, budget permitting. I'd also step up all the fasteners to ARP high grade. I've got part numbers and specs up here
ARC
57
Feb 21, 2022 10:54 AM
