cam installation tools
What tools did you guys use when changing your cams. Did anyone use the JPR cam install tool.
http://www.thunderracing.com/catalog...d=108&pcid=171
I just read somewhere in the ls1 section that the tool will not fit newer model heads. And I just ordered one yesterday.
Good luck
I use a cheap screw type I got from Oreilly. I had one that you screwed into the stud hole then pried on it, but I broke two screws in the head, and that sucks. Somewhere they have one I think Thunderracing that looks like a rocker but is notched so you can get the keepers out, and you use a 3/8 drive ratchet to compress the springs. if I would have had any Idea how many times I needed the spring compressor, I would have spent the $$$.
I had that on order but they said it would not be available until mid to late Feb. I cant wait that long.
http://www.vincihighperformance.com/superwebdeals.HTML
Originally Posted by BBT
I have the crane double spring tool and it works great...I bought it from Vinci
I also have the JPR tools and they worked fine on my 99 5.3, but I've heard that they don't always seem to work on the newer blocks.
Whistle Truck Guy
The cam swap in my truck was done with 16 of those little pen magnets. Prolly not the cheapest way to go, but hey, how many uses are there for pen magnets in the shop? Last time I checked there were quite a few. Since the rocker arms had to come off anyway, I just put a magnet down each pushrod hole and rotated the cam to make sure all the lifters were up, and they held just fine. I have heard of people just turning the cam and hoping the lifters stay up in the lifter guides. Sometimes this works, but I wouldnt want to be there for when it doesnt work. Fishing lifters out of the oil pan isnt my idea of a good time.
all_individual
Jul 13, 2015 11:01 AM
