LM7, 243's, 4.8L pistons
Old Jun 20, 2020 | 08:38 AM
jcarl126's Avatar
Default LM7, 243's, 4.8L pistons
Bit of a Franken-engine here,
243's milled 0.020"
LM7 block with TSP stage 4 High Lift Cam (0.600"/0.600) and PAC 1219 springs
4.8L heads on LM7 rods and crank
Am I going to have clearance issues here running a stock head gasket or 0.045" thick gasket with the 3.910 bore size? I know i will need a pushrod checker but obviously want to avoid valve contact while getting a nice compression bump for NA and 93 oct only
Thank you for the help!
Old Jun 21, 2020 | 02:47 AM
1FastBrick's Avatar
Custm2500's Rude Friend
GM did the same basic engine minus the cam and called it an L33.
Old Jun 21, 2020 | 02:58 PM
1994Vmax's Avatar
Probably not even close but a little play dough goes a long way.
Old Jun 23, 2020 | 05:04 AM
jcarl126's Avatar
awesome thought! Hadn’t even crossed my mind to do that, thank you guys
Old Jun 23, 2020 | 05:05 AM
jcarl126's Avatar
right I just am not sure with the heads missed and large cam if it would make a huge difference. Would love to find some l33 pistons but 4.8 I think is the same p/n if I’ve researched correctly
sross
Feb 20, 2017 09:33 PM
zaathur151
Dec 19, 2016 01:33 PM
racinmason8
Dec 9, 2016 11:39 PM
slimcracka
Sep 19, 2015 05:11 PM
00buckshot
Sep 28, 2011 10:19 AM
