LM7, 243's, 4.8L pistons
Bit of a Franken-engine here,
243's milled 0.020"
LM7 block with TSP stage 4 High Lift Cam (0.600"/0.600) and PAC 1219 springs
4.8L heads on LM7 rods and crank
Am I going to have clearance issues here running a stock head gasket or 0.045" thick gasket with the 3.910 bore size? I know i will need a pushrod checker but obviously want to avoid valve contact while getting a nice compression bump for NA and 93 oct only
Thank you for the help!
243's milled 0.020"
sross
Feb 20, 2017 09:33 PM
