Which lifters and head gaskets?
Old Nov 2, 2013 | 10:00 AM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
Default Which lifters and head gaskets?
Which lifters should I run when I do my head and cam swap? BTR or ls7 lifters? Should I install new trays as well? Motor has 100k on it. Also heads are 317's milled .030" on a lq9. Which head gaskets would you recommend an size? Motor is a strong N/A motor that will see a 200 shot of nitrous. It is has head studs as well.
Old Nov 2, 2013 | 10:49 AM
TXsilverado's Avatar
are you wanting stock thickness gaskets? if so LS9 gaskets. lifter trays are only about 3$ per tray. lifters are up to you. LS7 or the Cadillac racing is where i would go.
Old Nov 2, 2013 | 12:38 PM
black00chev's Avatar
Slowest turbo build ever!
After my own personal experience and seeing a few others on here with similar issues, skip the LS7 lifters and go with either the Caddy or Brian Tooley lifters.
Old Nov 2, 2013 | 02:44 PM
Beatdown Z's Avatar
Laid Back
summit racing has a lifter and tray kit for a good price. I used it in my rebuilt ls2 and they're working great. I think scoggin dickey has the same kit for around the same price too.
Old Nov 2, 2013 | 02:52 PM
Noah Burns's Avatar
what issues would that be?
Old Nov 2, 2013 | 03:57 PM
gamble686's Avatar
The issues seem to come up on aggressive cams. Over 230 duration and over .620 lift.
Old Nov 2, 2013 | 04:14 PM
which is why i stuck with my old school ls2 lifters. requires a .050 longer pushrod, but i don't hear of problems from them.
Old Nov 2, 2013 | 04:40 PM
BLKSSLTT's Avatar
Would my 06 lq9 already have the ls2 version ? Is it worth to put new ones in or run why I have?
Old Nov 2, 2013 | 05:41 PM
how many miles do you have on them? it's a judgement call. how often do you have the heads off to replace the lifters?
Old Nov 2, 2013 | 06:02 PM
TURBHOE's Avatar
what's this ls7 high lift lifter problem? what happens?
