Which lifters and head gaskets?
formerly turbo4.8 (2014-06-25)
Which lifters should I run when I do my head and cam swap? BTR or ls7 lifters? Should I install new trays as well? Motor has 100k on it. Also heads are 317's milled .030" on a lq9. Which head gaskets would you recommend an size? Motor is a strong N/A motor that will see a 200 shot of nitrous. It is has head studs as well.
