Lifter suggestions
Old Jan 20, 2014 | 01:54 AM
SumtinCoo's Avatar
Default Lifter suggestions
Hi I need some new lifters in my 370 that I'm building. I had ls7 lifters in this motor when it was a lq9 std 4" bore and I sprayed it with a 150 shot and melted a hole in the #7 piston. I can't remember if it was the intake or exhaust on the #7 but one of my lifters cracked around the roller but luckily didn't trash the cam or cause any further damage. So now I don't want to use them and use a nicer more reliable lifter with link bars. It's a rcsb with a t56, 4.56s, and a 234/242 .629/.629 112 eps pat g with PAC 1209x springs rated to .750 lift. Stock rockers with the trunion upgrade and a 7.425 pushrod. It may get to 6500rpm every now and then but this is my daily driver so won't be punished 24/7
I'd like to keep the cost under $400 and have these lifters in mind
Morel 5290
Lunati 72332
Howard's cams 91166
Any good or bad or any other suggestions would be great. Thanks!
Old Jan 20, 2014 | 06:44 AM
batboy's Avatar
11 Second Club
To stay within your budget, get the Morel 5290 from Brian Tooley Racing.
Morel 5290 LS Link Bar Hydraulic Roller Lifters - Brian Tooley Racing
By the way, Morel makes the Lunati lifters.
Old Jan 20, 2014 | 07:24 AM
skeet's Avatar
morel
Old Jan 20, 2014 | 12:44 PM
SumtinCoo's Avatar
I had heard that before. Does lunati do anything different to them once they get them or are they exactly the same?
Old Jan 20, 2014 | 06:02 PM
tim wellington's Avatar
Default lifter
do u still use the stock lifter trays with link bar lifter
Old Jan 20, 2014 | 06:04 PM
1FastBrick's Avatar
Custm2500's Rude Friend
No. The tie bar keeps the lifters from turning like the stock tray does on a factory style lifter.
Old Jan 20, 2014 | 06:18 PM
batboy's Avatar
11 Second Club
Like was said, the link bar lifters eliminate the need for lifter trays.
Old Jan 20, 2014 | 06:35 PM
Default lifter
so once you go to this style lifter you cant do the cam trick with dowels .to change cam .since the lifter tray hold lifter up while you change cam
craigsix's Avatar
scoggin dickie has the cadillac lifters.
Old Jan 21, 2014 | 11:23 AM
Scoggin Dickey's Avatar
Former Vendor
We have the Morel 5290 lifters in stock as well, $319. they aren't on my site for some reason, but if you give us a call we can set you up
