Lift question
Old Feb 20, 2007 | 05:43 PM
99/5.3w/hips's Avatar
Default Lift question
What exactly does higher or lower lift on a cam do? For example what would be the difference on a 224/224 .563/.563 112 versus a 224/224 .588/.588 112? Can some explain the difference that lift makes in terms of how much HP or Torque a cam makes?
Old Feb 20, 2007 | 08:17 PM
budhayes3's Avatar
PT's Slowest Truck
The higher the lift, the higher the valves will riase off the seat...basically higher lift = valves open further. With more lift, you can get more air/fuel in, and exhaust out. If you have the proper tune, cubes and mods to support it, more lift=more power . On a negative note, more lift also equals less valve spring life
Goat's ss
Jan 6, 2016 12:14 PM
GXPJAY
Nov 5, 2015 06:49 AM
YenkoST
Aug 28, 2015 01:42 PM
spiritfish
Aug 23, 2015 09:58 PM
USMCvet0311
Aug 1, 2015 07:45 AM
