knock sensor replacement
Old Jul 29, 2006 | 02:37 PM
skindog39's Avatar
Default knock sensor replacement
Hey guys,
I am replacing the knock sensors on my 2001 4.8L Silverado. I got the intake off (after a good bit of trouble). However, now I am at the part where I have to take the old sensors out. HOW THE HELL DO I GET THE PLASTIC WIRING CONNECTOR OFF THE TOP??? And, how do I then remove the old sensors? Thank you so much. Any help would be much appreciated.
Old Jul 29, 2006 | 03:12 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Pry out the rubber boots and then use 2 flat head screw drivers or a pair of long needle nose plyers to get the plugs off the sensors (its a squeeze style plug). From there, the knock sensors screw out (use a 7/8 socket).
Old Jul 29, 2006 | 04:53 PM
ktmrider's Avatar
TB is exactly right. Squeeze the plastic ring ( very, very hard ) and as it bows out on 2 sides it will come off the sensor.
Try not to bang the new sensors around as they are sensitive to excessive vibration and could be damaged.
OHsixLS3
Dec 27, 2016 09:30 AM
Fast86z
Aug 23, 2015 12:35 AM
Jblake
Aug 17, 2015 12:59 PM
OHsixLS3
Aug 10, 2015 07:19 PM
04450r
Jul 30, 2015 02:04 PM
