intake question
Old May 23, 2006 | 02:10 PM
912jonathon's Avatar
Default intake question
would i be alright to put a ls6 or ls1 car intake on my truck? i now i will lose bottom end but with the 3800 stall it dont matter. and what all is needed to install this intake on my truck??
Old May 23, 2006 | 10:49 PM
https://www.performancetrucks.net/fo...7&page=1&pp=10
there's kano's write up. you will not lose much bottom and will prepare yourself to decently gain up top depending on where you are shifting at. i wouldnt do it unless you plan on revving to the upper half of 6000 rpms or something. the install write up above is for fly by wire throttle body and is much simpler if you have cable driven but i dont think you do with your 2003
Old May 23, 2006 | 11:29 PM
Okie5.3's Avatar
talked with brian at TEA for an hour the other day about some heads, and the subject of intakes came up. his suggestion. FAST 90 and the LS-2 TB. not gonna lose a damn thing. don't need the vacuum reference like carb motors do. all we need is air and lots of it.
Old May 23, 2006 | 11:37 PM
the fast intake IMO is way to over priced and not much different than the LS1/6 intake... its about twice as much as an ebayed LS6 intake
Old May 23, 2006 | 11:53 PM
Okie5.3's Avatar
agree with the overpriced. i am on the look for an intake of some sort, LS6 or used FAST 78, for the next mod.
Old May 24, 2006 | 10:36 AM
Z284thgen's Avatar
11 Second Club
you need to come off with a bigger cam and hook me up with that one
Old May 24, 2006 | 04:58 PM
Silver LT's Avatar
Default Intake flow ratings
Flow ratings for the three intakes (from an LS1TECH thread).
LS1 Intake
.200 .300 .350 .400 .450 .500 .550 .600
141- 185- 205- 222- 232- 241- 251- 258
Truck Intake
163- 206 -224 -237 -249 -262 -265 -270
LS6/00-02 Intake
166 -211 -229 -244 -257 -269 -277 -283
Old May 24, 2006 | 07:25 PM
Quik's Avatar
5 year bitches!
i run the ls6 intake on my truck, i also have a 3800 stall. as for back to back comparisons i dunno i did an entired swap/setup and all i can say is the truck is strong
Old May 25, 2006 | 12:45 AM
that post makes the truck intake appear to flow better all around but i thought on the high end due to the plenum volume the ls1 still flowed better??
Old May 25, 2006 | 01:56 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
get an LS2 intake with a 90 mm T/B the intake is for 245$ LS2 intake manifold = 89017648 or 12589181 and the LS2 90MM T/B is for 231$ part#12570790
