I think I broke a patriot gold spring
Old Mar 2, 2010 | 05:59 PM
jophuss36's Avatar
Default I think I broke a patriot gold spring
I am having a missfire in cylinder 4, I changed plugs wires and coils. Still the missfire. I switched fuel injecters for cylinder 4 and 2. Still cylinder 4. I havnt pulled the cover off yet but I'm pretty sure it's a broken spring. What spring would u guys recomend? I'm going to do a cam swap in a few weeks too. My new cam will be a cam dr. 232 236 113 with lsl lobes 613 617 lift I beileve
Old Mar 2, 2010 | 06:37 PM
zeake's Avatar
Pull the cover. I don't get out much but I have never heard of a broken patriot gold spring.
Bent push rod maybe
Old Mar 2, 2010 | 06:47 PM
jophuss36's Avatar
Ok if it was a pushrod that wouldn't be so bad. I think I'm going to go out there now and pull the cover
Old Mar 2, 2010 | 06:51 PM
hirdlej's Avatar
I've seen broken patriots. Not often, but I have. Go with a PAC 1518 spring for a set of replacements. Put near indestructable
Old Mar 2, 2010 | 06:54 PM
dirt track racer 81's Avatar
Did you use the partiot spring seats and valve seals or the stockers?
Old Mar 2, 2010 | 06:59 PM
2005 Silverado's Avatar
SPAM HUNTER
Patriots are high maintenance, the are supposed to be checked every 10,000 miles for correct spring rates.
Just throwing that out there, but i have never heard of a broken one.
Old Mar 2, 2010 | 07:12 PM
jophuss36's Avatar
I used everything patriot
Old Mar 2, 2010 | 09:43 PM
jophuss36's Avatar
Ok I didmt take the cover off yet but I did a compression check and the other cylinders were 190 lb per inch and the bad cylinder was 5 lb..... Hope it's not worse then a spring
Old Mar 2, 2010 | 09:44 PM
Atomic's Avatar
I have a gauge for that
Wouldnt it have been much easier to pull the valve cover?
Old Mar 2, 2010 | 09:50 PM
jophuss36's Avatar
Lol no not really one of the bolts heads were striped
