I think I broke a patriot gold spring
I am having a missfire in cylinder 4, I changed plugs wires and coils. Still the missfire. I switched fuel injecters for cylinder 4 and 2. Still cylinder 4. I havnt pulled the cover off yet but I'm pretty sure it's a broken spring. What spring would u guys recomend? I'm going to do a cam swap in a few weeks too. My new cam will be a cam dr. 232 236 113 with lsl lobes 613 617 lift I beileve
Ok I didmt take the cover off yet but I did a compression check and the other cylinders were 190 lb per inch and the bad cylinder was 5 lb..... Hope it's not worse then a spring
