I need help lol. ( new to this ) don’t bash me.
#21
well from your codes id almost guarantee you have a serious vacuum leak on your intake manifold. I’d take the intake off and check my gaskets out. I had the same problem one time and while putting my intake back on one of my injector safety clips caneboff and got wedged in between my intake and gaskets on bank 2. That’s where I would start! From your codes it also seems like you have a evap leak somewhere too. I’d check all those connections out too
#22
hey back for your help once again !!? Still have the lagging and fuel issue. Injectors are fine, Rail is fine, lines fine. Upon start up fuel pressure is 55-60 then drops to 40. Replaced pump still have the same issue. Canister is fine, cleaned mass air flow ( didn’t replace it ) and still the same. I just want to drive my truck lol. Pleaseeeeeeeeeeeeeee help me also no vacuum leaks smoke tested and all !!
#24
Slowest_1500
09-15-2013 10:49 AM
hyper
21
10-12-2003 10:50 AM
