pics posted need input
Old Apr 10, 2018 | 07:07 PM
stroker87's Avatar
Default pics posted need input
have a 6.2 block at the machine shop plan was to take it .005 to clean it up and install a stroker crank H beams and forged pistons set it up for nitrous. was told by a few guys not to go over 4.070 bore since i want to spray a 200/225 shot true it (maybe less depends on N/A #'s)
right now the block is at 4.06950 shop wants to take it to 4.072 or 4.075
is it ok to run at 4.070 if these marks dont clean up 100%?
if we go to 4.072 and stick a 4.070 piston in it is that ok?
so lost with this
Old Apr 11, 2018 | 12:22 PM
stroker87's Avatar
bump for advice
Old Apr 11, 2018 | 03:27 PM
FFDP's Avatar
Do you really think .002 is going to matter?
Either way you have to have those walls cleaned up. Do the very minimum amount each pass and see what it takes to remove that stuff.
Old Apr 11, 2018 | 05:46 PM
stroker87's Avatar
Originally Posted by FFDP
Do you really think .002 is going to matter?.
i honestly dont know?
if i leave it like that and run it what would cause or do?
Old Apr 14, 2018 | 09:29 AM
parks450's Avatar
Can you feel those Marks?
Old May 10, 2018 | 01:02 PM
Blackout-88's Avatar
.0031" is the service limit on 4.8 lr4, gernerally 0.001" for every 1" of piston diameter for service limit, you should be fine to run it with .002".
From service manual
Old May 10, 2018 | 01:04 PM
and I would get some one else to cross hatch that it should be 45 degrees
GTOsRamairSilverado
Jan 25, 2008 08:44 AM
Ross @ EDO
Apr 18, 2006 12:26 PM
onyxsilverado
May 17, 2005 09:43 AM
BlownChevy
Jun 11, 2003 08:17 AM
KeukaZ71
Mar 29, 2003 11:06 AM
