I have a theory (check my logic)
Old Jul 16, 2007 | 02:02 AM
  #41
thunder550's Avatar
High on diesel fumes
Originally Posted by ZZebes
i mean the 408 has become a regular thing but someone trying to run 12's in a beefy *** 5.3L is different i guess.
kbracing96 ran a 12.79 @ 105 with his 4.8L STS 4x4 ECSB, 210/218 cam @ 12 psi
Old Jul 16, 2007 | 10:02 AM
  #42
ZZebes's Avatar
Well tousche than
So i thought it over and here is how i may go after i make some phone calls today.
Iron Block 5.7L
Forged Internals (9:1 Comp)
Trick front mount turbo
Gearing undecided
Keep my 3200RPM converter
Keep the FLT or get it upgraded to a Level 5
Old Jul 16, 2007 | 10:37 AM
  #43
nighthawk08's Avatar
if you do decide to stay NA. here's what I would do:
find a L33 in a junkyard for 1000
rod bolts
have the heads p/p milled
and of course a big cam.
Old Jul 16, 2007 | 10:43 AM
  #44
zippy's Avatar
The LS4 and L33 use the same cylinder heads and the same pistons. If I were going to build an engine to do what you're doing, I'd get an L33 and use LM7 cylinder heads with bigger intake valves installed and ported. That will bring your compression up. The stock lower end is just fine, just change the rod bolts. All of that with the right cam and a better intake manifold is about the best you can ask for without spending more than it's worth to get your goal.
Old Jul 16, 2007 | 10:51 AM
  #45
ZZebes's Avatar
thanks Zippy, i think i may go boosted cause thats like crack. but i have to call some suppliers. i have to call and talk to richard and then trick and then i have to find someone to build the 5.7
i think i may slap a turbo on my 5.3 and start the new motor fund and when its full i'll turn up the wick and see what she'll do.
Old Jul 16, 2007 | 11:17 AM
  #46
Silver-Dollar's Avatar
how about this 5.3 486hp/425tq
https://www.performancetrucks.net/fo...d.php?t=386962
direct
http://www.racingjunk.com/post/82332...ip-Engine.html
Old Jul 16, 2007 | 11:29 AM
  #47
ZZebes's Avatar
jesus, thats a big duration cam
Old Jul 16, 2007 | 01:59 PM
  #48
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I'm a bit confused here. Why put another stock crank in? Just change your pistons to either some forged flat tops (or stocker GM flats) and possibly go to some high spin rods.
Apologies if I've missed the point
Old Jul 16, 2007 | 02:02 PM
  #49
ZZebes's Avatar
i was gonna start with a fresh block and fresh crank. but i believe i am going turbo.
Old Jul 16, 2007 | 02:04 PM
  #50
I AM A MOTHERF*CKER
AH I gotcha now.
Turbos are better anyway
What kind of kit are you looking for?
