i got lucky
Old Dec 9, 2012 | 07:01 PM
Area47's Avatar
Default i got lucky
ls9 valve spring. or was.
roughly 15k miles. max of 6700 rpms.
Old Dec 9, 2012 | 07:36 PM
2000chevysilverado's Avatar
yep could have turned out really bad
Old Dec 9, 2012 | 07:38 PM
TIM Z's Avatar
11 sec. Truck Mod
And you heard a noise I take it ?
Glad it didn't bite ya
Old Dec 9, 2012 | 08:00 PM
ak2007r6's Avatar
Glad it didn't end up worse!
Old Dec 9, 2012 | 08:04 PM
Ferocity02's Avatar
How did you notice it? How much lift are you running?
Old Dec 9, 2012 | 08:13 PM
oakley6575's Avatar
Also interested in the lift..?
Old Dec 9, 2012 | 08:30 PM
Wheatley's Avatar
Truck Sponsor
Damn,that sucks!!
Not cool to see
Old Dec 10, 2012 | 10:19 AM
Area47's Avatar
when i would cold start the truck it would tick it's *** off. i just took it as the usual ls engine lifter/piston slap stuff below 40 degree's. pull the valve covers off and did a push rod length check to see if the pushrods were a bit short, or something else was wrong. push rods came up fine in length. so, now i have a set of .025 over rods for no reason.
got to looking at the springs and noticed one was not right, or not sitting like the others. noticing inconsistent air flow numbers on back to back pulls. little things here and there that didn't seem right.
noise, visual, and data log info.
the cam in the truck right now is .500 lift. the ls9 cam i had in it was .562"/.558. the springs are the part number supplied by gm for the ls9 springs.
Suburban2500
Jul 13, 2015 09:57 AM
01Blue4.8
Apr 12, 2006 10:14 PM
ThunderZ28
Apr 7, 2006 02:56 PM
TXsilverado
Aug 10, 2005 01:46 PM
ranwalk
Dec 26, 2003 05:02 PM
