Holy Sh*t the knock was loud this morning!!
Old Dec 26, 2003 | 09:22 AM
ranwalk's Avatar
Default Holy Sh*t the knock was loud this morning!!
Did the usual, started the truck to let it warm up before i go to work. Sounded fine for about 10-15 seconds than holy ****, it started knocking/banging real bad for about 10-15 seconds then it faded away. I just knew it was going to lock up on me.The noise faded away shortly. I think my problem is a rod knocking and not piton slap. I'll know Saturday when I drop the pan again. Fingers are crossed that it's just a loose or stretched rod bolt and hoping if so that the crank and all are ok. If I'm extrmely lucky I may be able to just replace the rod bolts.
Everyone keep your fingers crossed for me. I'm usually not that lucky.
Old Dec 26, 2003 | 09:58 AM
Good luck ranwalk.
I haven't heard of many lower end problems with these motors,but your making more torque than most.
Old Dec 26, 2003 | 09:59 AM
Flyer's Avatar
I'd replace rod bearings off any bolts you pull too.
On the up side ... I had a truck with a rod knocking, that ran for a while that way. It shouldn't lock up, it will just slinge one through the block if anything, not to mention really buger up your crank.
Old Dec 26, 2003 | 10:10 AM
BigKID's Avatar
If it was a rod, it wouldn't go away would it? I still think it is a lifter that is having trouble pumping up. When I put my cam in, I thought my stuff was going to blow up it sounded so bad till the lifters finally primed back up. I still have one on the pass side that takes longer than the rest upon startup.
Old Dec 26, 2003 | 10:31 AM
ranwalk's Avatar
Slinging a rod through the block is an upside???
If it is a rod and can be saved, where is the best place to get ARP rod bolts from??
Old Dec 26, 2003 | 03:12 PM
gonzo 6.2's Avatar
What BIG KID said exactly
Old Dec 26, 2003 | 05:02 PM
parish8's Avatar
single digit dreamer
i have a noise that is way worse when cold and it sure sounds like a rod to me, seth at cmotorsports says his truck has a rod knock also.
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Rockrz
Sep 29, 2015 09:07 AM
