I Finally did a leak down...
Old Nov 3, 2007 | 06:36 PM
  #31
Wilde Racing's Avatar
How do I change this text
Csk??
Old Nov 3, 2007 | 06:40 PM
  #32
ZZebes's Avatar
Originally Posted by Wilde Racing
Csk??
Cold Start Knock
Old Nov 3, 2007 | 06:45 PM
  #33
moregrip's Avatar
what a rush!
thanks for the update
Old Nov 3, 2007 | 06:50 PM
  #34
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I doubt it is anything to do with the design/pieces of the motor more like too much hp for stock hypeurtectic pistons. Its common over on tech, once you get in the 550rwhp range the ring lands start giving up the ghost and thats exactly what happened here IMO. I doubt you had any knock with the metric ton of meth you were spraying, probably more like extremely high cylinder pressures from 14#s of boost. Running your numbers through a calc assuming a race weight of 5K, you should have been in the 650rwhp range. Thats about 800 at the crank, thats alot to ask of stock internals.
Zzebes if the boost amplified the piston coming out of the hole at BDC he would have bearing problems since the only parts that can shift at all are the bearing tolerances.
Old Nov 3, 2007 | 07:31 PM
  #35
No CKS, and the truck wight 5,000 with no seat spare or drop hitch, so yes the engine was make more than double the stock hp....
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
