Hydrolocked?
Old Mar 25, 2007 | 01:02 AM
ShoCKer354's Avatar
Default Hydrolocked?
ok so i went off roading on friday, thought i might get the truck a little dirty. well i went through one water hole with out any problems and got a little cocky. then i desided to go through another one well it was a lot deeper than i tought. the engine seized and i had to get her towed. after about two and a half hours and maybe 2 gallons of water we got the top end off to find two rods broke. it was the two cylinders on the back of the engine (i believe its the 7 and 8 cylinders) i still need to get a lift so i can pull the engine. but what i am curious about is how easy is it to knock the crank off balance and also if those two pistons fire right after each other. right now im just hoping the engine died fast enough so the broken rods didn't smack the cylinder walls.
Old Mar 25, 2007 | 01:18 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
It will be easier/cheaper to find someone on here with a good running shortblock rather then wasting the money on rebuilding it. If you give a few more details about your vehicle someone may be able to help you.
Old Mar 25, 2007 | 10:43 AM
ShoCKer354's Avatar
i have an 02 silverado z 71 everything is stock on it.
Old Mar 25, 2007 | 11:26 AM
1slow01Z71's Avatar
Where are you located? Your best option is to find someone with a 5.3 or if you have the cash call local junkyards and find a good running LQ4(6L out of the HD trucks) and you will have noticeable bump in hp and tq.
Old Mar 25, 2007 | 11:28 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You might also PM Mater. He runs a salvage yard in PA I believe.
Old Mar 25, 2007 | 11:40 AM
1slow01Z71's Avatar
Here are some motors for sale on here
https://www.performancetrucks.net/fo...d.php?t=388389
https://www.performancetrucks.net/fo...d.php?t=386405
Old Mar 25, 2007 | 06:08 PM
ShoCKer354's Avatar
a few buddies of mine are helping me with the tear down right now. but we found a 5.3 long block with 47,000 miles on it for $750. i think i'm just going to go with that and sell what ever is still good off my old motor. thanks for all the info and advise
Old Apr 4, 2007 | 12:02 PM
trxmxzx's Avatar
13 Second Truck Club
Okay well I'm one of his buddy's, anyways the motor is in... now it runs ..... well at 2000-2500+ it throws a multiple misfire code and Cylinder # 4 misfire! WTF
it runs kind of rough at Idle when the SES light Is FLASHING (isn't that a very bad sign?)
now when it says multiple misfires does that mean spark knock sensors picked that up?
MAF got really wet when he obviously hydro-locked it... might be an issue took mine of my truck it ran a little better not much though. His O2s are bad ....I think the both back 2. would the water mess the front ones up at all?
What might we be looking at on this? I'm thinking plug wire are messed up and need to be replaced (I hope) (originals 86k and they where a pain to get off so might have broke in the inside!?!?)
his muffler had about 2-3 gallons of muddy water in it when we started it- it couldn't breath so we helped it out by putting a bigger hole at the back of the muffler (drain it out)...
I'm tired of working on this any input would be great... Thanks
Old Apr 4, 2007 | 06:28 PM
GMGen3's Avatar
Flashing SES means catalyst damaging misfire (very rich). If the back 2 O2 sensors are bad, it will not affect the running of the engine; they are only catalyst monitors. If you are suspicious of a bad wire, swap it with one of yours. Also, think about what came with the motor and how much of it was put together. You may end up backtracking and fixing someone else's f-up.
Old Apr 4, 2007 | 06:31 PM
BlownChevy's Avatar
blownerator
25 Year Member
I have a NICE new 6.0L LQ4 long block i can sell ya.
2100 plus shipping.
