how in the world do I change the valve springs...?
Old Aug 8, 2016 | 09:18 AM
Tigger Welder's Avatar
+1 to TrendSetter, Since I have a MIG, I went ahead and welded it in rather than thread it and use JB Weld, but both ways are good. I haven't done this on an LS, but on my Nissan L6 the cylinder has to be pretty much right on TDC or the compressed air will spin the engine around! Also, it helps to pop the retainer with a rubber hammer before you try to use the spring compressor, sometimes they are really tight.
Old Aug 14, 2016 | 06:30 PM
nitrousaddict's Avatar
Thanks guys. once i figure out fixing my trans i'll get on it. cant wait for the cam
Old Aug 14, 2016 | 08:47 PM
Wolftrk99's Avatar
If you go with a compression tester hose, may need to pull the valve core out of the end, most of them are one way valves.... Still easiest and quickest and can be had at parts stores for about $10-20 for a cheap one.... As stated it is very doable just make sure you have the proper tools and TAKE YOUR TIME!!! Plan minimum of a long weekend for the springs and about a day for the cam, being that its your first!!!
Old Aug 14, 2016 | 08:49 PM
Wolftrk99's Avatar
Or a 19mm socket hit with a hammer on the retainer will loosen the keepers up as well....
Old Aug 16, 2016 | 07:47 PM
TrendSetter's Avatar
non metallic hammer on the keepers at an angle is better IMO. wont mar up the keepers or shock any of the parts as bad.
Old Aug 16, 2016 | 09:51 PM
Wolftrk99's Avatar
Socket doesnt mar the keepers, one sharp whack with a 24oz ball peen will on occasion knock the keepers out(which i dont recommend doing in the vehicle...just tap them to loosen them) i use a rubber mallet on the valves to make sure the valve locks are seated properly arent coming back out, after swapping them. Maybe its old school practice but i was taught (by someone much wiser and experienced than i will ever be) a while ago to do so and i have never had a valve drop...
Old Apr 4, 2019 | 01:27 AM
cammednnbs's Avatar
The cheap harbor freight compression test kit has the right size to hold valves up and the trickflow valve compressor works great.
Use wooden dowels to hold lifters up
Pretty easy i would plan 2 days if its your first time.
Get an arp crank bolt its hard to stretch oe bolt
Old Apr 4, 2019 | 05:46 AM
Resolute_welding's Avatar
This thread is from 2016 lol. I hope he's gotten it figured out.
Jake75
Apr 11, 2016 08:53 PM
4xRCSS
Mar 4, 2016 09:40 AM
lopy6oh
Mar 1, 2016 08:37 AM
shyster7
Apr 22, 2002 01:37 AM
Phatchevy
Mar 28, 2002 08:28 AM
