how much lift untill reliefs are necessary?
Old Dec 13, 2008 | 08:10 PM
00Silv4.8's Avatar
Question how much lift untill reliefs are necessary?
Like it says... It looks like Im about to get a cam for the 6.0 with some where in the neighborhood of .635 lift (iirc). Guy said he had valve reliefs and told me I may need to. Its going in an LQ4 with 241's. Thanks for any input guys
Old Dec 13, 2008 | 08:13 PM
Hawk179's Avatar
measure and you will know.
R
Old Dec 13, 2008 | 08:37 PM
Wilde Racing's Avatar
How do I change this text
R
yep, every engine could be different........ MEASURE IT
Old Dec 13, 2008 | 08:40 PM
Mangled03gmc's Avatar
Baltimore Whore
You better have the heads flowed, worked for a cam that big, other wise, you aren't really going to gain that much from it
John
Old Dec 13, 2008 | 08:43 PM
dirt track racer 81's Avatar
had those heads with an lq4 before. your better off with 6.0 heads milled or 243 heads
Old Dec 14, 2008 | 01:43 AM
lsx10's Avatar
John
listen to this man, that cam will be a dog with stock heads, port them and that engine will be a beast. if you're tight on cash but mechanically inclined then check out this.
https://ls1tech.com/forums/generatio...end-seats.html
dirt track racer 81- had those heads with an lq4 before. your better off with 6.0 heads milled or 243 heads
a good set of ported 241's will be just fine, the cam he's running will need ported heads no matter what casting.
Greg
Old Dec 14, 2008 | 03:29 PM
00Silv4.8's Avatar
dam really? thanks for the input. I didnt figure a donkey dick cam needed more work. Good thoughts, and thanks for the link LSx
Old Dec 14, 2008 | 03:35 PM
00Silv4.8's Avatar
just read over the thread... Im not too sure on my abilities to port my own heads, Im too affraid to foobar it. So I understand that the 243s had a different casting procedure making it a smoother combustion chamber. Is that why the 241s are usually not a 1st choice?
Old Dec 14, 2008 | 04:33 PM
Hawk179's Avatar
243's have a double quench area in it, hence it being the head that can take more timing and produce better power.
R
Old Dec 14, 2008 | 04:52 PM
00Silv4.8's Avatar
got ya. I guess my goals were wrong then. I was only looking for more compression. So even with my 221/221 should I need to port the heads or would it be ok how it is?
