How high is too high?
Old May 24, 2008 | 02:18 AM
Spoolin's Avatar
GFYS and STFU
Default How high is too high?
How many of you are running oil coolers?
I never had an oil temp gauge until recently and now that I have one I'm always starring at it since it's usually pegged out @ 250F if I'm not driving like a 80 year old woman. Even on hot days it'll get pegged just running around town in stop and go.
Ideal engine temp is between 160-180 right? And my radiator and coolant are doing fine keeping my engine temps in that vicinity so I know I'm not overheating and everything is working properly but I'm worried my oil temps are getting to hot and possibly as hot as 500F-600F when I'm in boost alot racing or driving like I stole it.
What's ideal oil temp to run at and who's got oil coolers and how are they working? Or am I just being paranoid?
Old May 24, 2008 | 07:15 AM
sharpshooter's Avatar
Man what weight oil are you running?Only reason I ask is because how thinned out is a standard 10w30 getting at those temps?I know a thicker oil won't change your temps but it might give you more protection from having any issues.
Old May 24, 2008 | 08:03 AM
AdioSS's Avatar
12 Second Club
where is it picking up the temps from?
Old May 24, 2008 | 08:09 AM
KySilverado's Avatar
I did a little reading on the subject just out of curiosity. Didn't really find anything on turbo engine temps. Most say oil pan temps of 230 is a max. Good synthetics a 300 max. Mind you this is an in pan temp.
Curious where you are taking that temp? IMO an oil cooler would not be a bad idea at all with a turbo setup. That or/and very frequent oil changes.
Old May 24, 2008 | 08:18 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yeah, too cool of a temp is not good on motor oil either. I lie to see temps between 180* and 200* on my bike, which is air/oil cooled.
Old May 24, 2008 | 09:44 AM
mwalls54's Avatar
Need More N2O Mod
I dont know what my oil temps get to but i have a large cooler infront of the tranny cooler with a small electrical fan pushing air thru it. since its a sss i have the small oil cooler in the radiator too.
Old May 24, 2008 | 09:58 AM
TG02Z71's Avatar
When you reach about 260-280* you are getting into dangerous territory.
Remember wherever the sensor is is not the worst case senario. You could be over 300* somewhere a hot spot resides and cooking small quantities of oil cannot be good for the overall condition of your oil.
Is your sensor f-ed up?
Old May 24, 2008 | 04:27 PM
Spoolin's Avatar
GFYS and STFU
I'm not sure where the sensor is, I'll have to find it but I'm pretty sure Rick didn't put it on the return line from the turbo. At least I wouldn't assume he did. I was running 10-30W and now it's 20-50W per my engine builders advice since it's broken in already. I don't think the sensor is messed up since it seems to read normal at start up and when the engine's starting to warm up and I can see it cool down to 200F on cool days and cruising, but I'll have to see where exactly the temp sensor is at, I hope it's not in the oil pan or I'm screwed!!
Thanks for the advice/help, I'll post back up when I find where the sensor is.
Old May 25, 2008 | 03:27 PM
ZO6Ted's Avatar
My Vette stays about 200-210 if that helps.
Old May 25, 2008 | 08:15 PM
Stoichiometric's Avatar
You need a cooler IMO. Lots of HP and a turbo will cause your oil to run hot. It will be cheap insurance in the long run. Until you get a cooler change the oil as often as you can.
